I believe it is going to be the only color there is ,,, blue,,, Chris is not quite sure on weather to keep it original blue or something like the new camery bright light blue. Unless he has change his mind. Correct me if i am wrong Chris.lovey80 wrote: What colour is she going to be?
Chris
Chridk Brumby, Subie Boys
rtcb65
Redneck Rick.
Redneck Rick.
- brumbyrunner
Yep Blue will be the colour.
And Steve i am starting to think you don't have hand, you just have wands of metalic magic. You wave them over the car and hey presto, shaped metal forms before your eyes.
Thanks again boys
P.s I picked up a bonnet scoop for Steve to massage into the bonnet
Cheers Chridk
Thanks again boys
Cheers Chridk
- last celtic warrior
Sorry Chris . I stole steve this week . Needed two brackets made to fit l rear suspension to my M.Y. . Need more cold gal and welding wire though. Ya brumby is sucking it up.
rtcb65
Redneck Rick.
Redneck Rick.
Dig past those butterflies, spiders, then get out the exit mold and a wire brush. Then put them all down and get ya wallet out. lol
rtcb65
Redneck Rick.
Redneck Rick.
Off the top of my head , not a clue. I will ask and let you know. I will post a pic so you can see what it looks like. What every you do, dont be in a hurry for it. We are as busy as a one legged man in a kicking contest.
rtcb65
Redneck Rick.
Redneck Rick.
- brumbyrunner
Are you talking about mounting the L series trailing arm housing in place of the MY torsion bar housing so you can ditch the torsion bars for coilovers? I cut the L series body mounts off one and welded on new mounts incorporating a 2" lift. Pretty big job to get everything to line up properly. I dunno how you'd do it with brackets alone.
Settlement Creek Racing
All i have done is put the l series coil overs in place of the M.Y. shocks. then wound down the M.Y. torsion bar . So now i am running on mostly the l coil overs. If need be , if i have a heavy load , i can always wind the bar up to asist if need be. It may sound sill to some people . But it works for me. Also if i dont like it . All i have to do is unbolt the l stuff ( 3 bolts ) and slip the shocky back in and wind the torsion bar up . No harm , no foul.brumbyrunner wrote:Are you talking about mounting the L series trailing arm housing in place of the MY torsion bar housing so you can ditch the torsion bars for coil overs. I cut the L series body mounts off one and welded on new mounts incorporating a 2" lift. Pretty big job to get everything to line up properly. I dunno how you'd do it with brackets alone.
rtcb65
Redneck Rick.
Redneck Rick.
- brumbyrunner
Oh that all Rick. I used to think that method of increasing your spring rate limited the wheel travel as the L rear shock has only 5.5" of stroke. But after a lot of trial & error and trying to achieve the impossible, I've come to the conclusion that it doesn't make that much difference. The big hinderence to wheel travel will always by the inner trailing arm bush.
Jeff dropped in a rex radiator so the mounts can be done now. Ya dont have to worry about the paint being stuffed by doing it later.
rtcb65
Redneck Rick.
Redneck Rick.
Chris has asked us to put his brumby on hold for a while. So we are going to have a small break and try to catch up on some of our cars. Then start again after new year . Dont know if we will be starting on chris's or the next one.
rtcb65
Redneck Rick.
Redneck Rick.
- beastofburden
