L 5 speed to M.Y
As brett posted earlier in this thread the M.Y flywheel is thicker than the L one. So it needs to be machined. It is now in the machine shop getting the ring gear removed and machined and the ring gear replaced.
rtcb65
Redneck Rick.
Redneck Rick.
wondering why you went with that method?rtcb65 wrote:As brett posted earlier in this thread the M.Y flywheel is thicker than the L one. So it needs to be machined. It is now in the machine shop getting the ring gear removed and machined and the ring gear replaced.
what i mentioned works perfectly for me and doesnt require machining
Wagon is no longer....
What engine is your 5 speed bolted to , ea81 or an ej.Matatak wrote:wondering why you went with that method?
rtcb65
Redneck Rick.
Redneck Rick.
Cleaned up the gearbox, ready to replace the front and back seal. The last thing i wont to happen is put the box in and find out in a month that the front seal needs replacing.
rtcb65
Redneck Rick.
Redneck Rick.
The flywheel is finished and i have cleaned up the shift linkages ready for the bushes. Also since my car has a 2" lift , i made up a couple of lift blocks for the L tail shaft .
rtcb65
Redneck Rick.
Redneck Rick.
I need some conformation on the following . We are about to the mods on the L linkages to fit the M.Y. . IS this right :- Shorten the mount and arm that the gear stick sits in.
:- The linkage arm to be shortened and have a light angle mod.
:- Range leaver to be lengthened
Can some one please let me know if this is right . I dont wish to waste a shift set.
Thanks to anyone who helps.
rtcb65
Redneck Rick.
Redneck Rick.
I just suck a 5sp D/R into an MY sedan and apart from massive trans tunnel mods the shifters went in prefect with no mods.
I used the original 2wd shifter rubber mount, turned it 90degrees and bolted the 5sp's rubber mount to it. Cut the hole out about 30mm to the rear and had to cut some out the front to clear the gear shifter. I have pics, I'll piut them up after dinner maybe.
- SUBIIE
ahh,
joined this thread a bit late but..........
most things to do with a MY to L series gearbox swap are in this website (see the address in the signature).
should answer all questions.
makes a massive difference after the old ea81 gearbox.
good luck
good luck
Pics as promised.
This is still going ahead . Just going into a different car. So if still interested in how it happens . Keep an eye out.
rtcb65
Redneck Rick.
Redneck Rick.
Interested to see how you go.. You're doing this because of 5th gear is that why?
Hey A.R.AlpineRaven wrote:Interested to see how you go.. You're doing this because of 5th gear is that why?
This is a test run. 1/ to see if we can do it.
2/ The low range and 5th gear
3/ to get to know the box so later we can remove the low range to put in a awd box , if i can ever find one.
rtcb65
Redneck Rick.
Redneck Rick.
Fair enough.. yeah it'll work out well. If its gonna be highway car with low amount of hills you could consider fitting taller ratios.rtcb65 wrote:Hey A.R.
You could use single range box instead of removing low range or find dual range AWD box.
Here are some picks i hope can help any one wishing to make up the selectors for the conversion. The gear stick shape is a personal thing of course. Shape it to suit your self.
rtcb65
Redneck Rick.
Redneck Rick.
- the gumbi brumby
Another small update on the thread. We used the L series starter , but it needs to be spaced out abit. Most people put a washer between the starter and the bell housing. I personally didn't like that. I am just picky. So made up a spacer plate to do the job.
When it came to the gearbox mounts. the L series are newer so we picked them. With that choice , new mounts to attach the mount to the box had to be made.
Depending if you have a lift kit or not the manual sway bar may get in the way. If you have a 2" lift or more , it doesn't seem to matter. If not lifted , you may need to swap out the manual sway bar for the auto. The auto one has a small curl piece in it.
rtcb65
Redneck Rick.
Redneck Rick.
Hey guys about how much needs to be cut off the linkages? Could you maybe post up some pics with deminsions add to them in paint or something?
Side note can you email me your address rick so i can get that engine drop off.
Matt
Matt
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
