Redneck Ricks Subie Boys M.Y.
Last of the Subie Boys cars are now on here. This is my M.Y. It has a few things done to it. In time it will be talked about.
Thanks to Steve , the replacement cross member with the cut out for the future turbo fitment is now done.
rtcb65
Redneck Rick.
Redneck Rick.
Hey rik,riksta wrote:Hay Rick, It's about time you put your Suby up on here.
Looks good, so when the new turbo going in?
Rik.
The turbo will be going in once i get every thing together. The plan is to ej up and run a awd dr box . Then if i can find one, some sort of a lsd rear. In saying that, plans dont always happen. Also the car has to go through the chook cooker . Have all the welding, bracing and rust repair done. But that doesnt happen till the brumby we are doing is finished, the other brumby is finished and a tarago is redone as well. So it is a little down the track yet.
rtcb65
Redneck Rick.
Redneck Rick.
That's right Rik. All our cars , mine, ross's and steve's will be going under the knife. We have been doing other peoples car and our own have suffered . So we are going to do ours once the brumbys are done.riksta wrote:So it's in line for the full works then, mite be off the road for a while, sounds like a good build up Rick.
Rik.
rtcb65
Redneck Rick.
Redneck Rick.
Spent some time wire brushing back the cross member and gave it a coat of cold gal. Now to just through the paint on.
rtcb65
Redneck Rick.
Redneck Rick.
I am now starting to get things together to fit a Crossbred Kit. Steve worked his magic and made some strut tops to fit the impreza struts to the M.Ys , to keep the impreza bearinged tops. I have a 2" lift , so just a matter of moding the strut tops to suit.
Also cleaning up a set of trailing arms to put new bearings and bushes for the rear.
rtcb65
Redneck Rick.
Redneck Rick.
Nice strut tops, you might be able to save abit of cash on the Crossbred kit cause you won't be needing the strut top adaptors that come with it now.
About time!rtcb65 wrote:That's right Rik. All our cars , mine, ross's and steve's will be going under the knife. We have been doing other peoples car and our own have suffered . So we are going to do ours once the brumbys are done.
Also let us know how your strut tops go as I've been thinking about doing the same to mine, although I found with my brumby I needed coilovers to go with the lift kit as well as jeffs kit otherwise there wasn't enough room!
87 targa brumby (Neglected),
+ others.
+ others.
A few more items cleaned up for the conversion, rear disks , 1 rear caliper , and tie rod ends. The tie rods are for the gc8 power rack that is going in around the same time.
rtcb65
Redneck Rick.
Redneck Rick.
Nearly all done . Only one more front caliper and knuckle and disk to go.
rtcb65
Redneck Rick.
Redneck Rick.
With the discs... what kind of paint are you using? (temperature rated etc)
Ive painted mine once with 300°c rated but it shows that paint has faded.
Hey A.P.AlpineRaven wrote:With the discs... what kind of paint are you using? (temperature rated etc)
I am just using the paint to stop any rust starting back up. It is only chassis black and fish oil. I dont think it will last very long, but it should last long enough , till i can get to put my car under the knife. I hope.
rtcb65
Redneck Rick.
Redneck Rick.
Now have a EJ 22 , computer and loom . Just have to cut the loom down. That will be interesting. Just waiting on the AWD box to be delivered and i can start to start setting my car up for the transplant.
rtcb65
Redneck Rick.
Redneck Rick.
- little_red_L
check out this thread! it talks about a loom adaptor from Subie-Wan-Kenobi. Would be a massive time/hassle saver.
showthread.php?t=5558
Red 1990 L series sportswagon: sports muffler, 4" lift, pod filter, powersteer conversion, pug 14's and a coupla stickers. with 27"s on their way. Everything else? Standard. For now....
I now have my liberty gearbox with the L series low range , thanks to a couple of people. A major , Major thanks goes to Alpine Raven for doing the L series low range for me . Also to Jeff for dropping it off on his way north.
Lucky for me, with Lovey80's loom here, i copied it and cut my loom down.
Tody i also removed my electric windows harnes ,( to be used in the Leone ) and fitted a L series electric window harness , so in the future, if i can get impreza door trims to fit, i have the window wiring fitted to suit the impreza trims.
rtcb65
Redneck Rick.
Redneck Rick.
Thumbs up.. Not a problem.
