The Brumbyrunner Project
Moderator: brumbyrunner
- Suby Wan Kenobi
- brumbyrunner
No and maybe.Suby Wan Kenobi wrote:Were the rear driveshafts spinning?
Clicking could be you have broken the centre coupling?
Car was in gear, tailshaft was spinning, driveshafts were not, car was not moving. Which, to me, means that the centre lsd ain't working at all because 100% drive is going to rear diff. And rear lsd ain't woking either because 100% drive is going nowhere.
Then came good enough to limp home but was slipping all the way.
How is that even possible?
Settlement Creek Racing
if your tailshaft is spinning and not youre driveshafts... then your rear diff has to be stuffed
your centre diff is only an lsd, so if theres much resistance to moving forwards and the rear drive can spin freeley, then all the drive will go to the rear, its only limited slip, not a locker
you mentioned that you managed to make progress in reverse for a few hundred metres,
so all it would have been was you either had a rock or bump in front of you when it first died, or was uphill and the centre lsd wasnt strong enough to get you moving,
but reverse was an easier option and it let you.
then once you were on a flatter or easier forward route it worked the same going forwards, once you had some momentum going then all was good.
but the more power you put down then the more its going to slip, so that woulkd probably be why you couldt go too fast
hows that for a theory
- brumbyrunner
Thats it, but when I stripped the rear diff down it was fine. Gears, splines, bearings all good. The viscous coupling has to be the culprit.bluesteel wrote:if your tailshaft is spinning and not youre driveshafts... then your rear diff has to be stuffed
you mentioned that you managed to make progress in reverse for a few hundred metres, so all it would have been was you either had a rock or bump in front of you when it first died, or was uphill and the centre lsd wasnt strong enough to get you moving, but reverse was an easier option and it let you. then once you were on a flatter or easier forward route it worked the same going forwards, once you had some momentum going then all was good.
Yeah yeah, I'm working on it. Finding one is proving difficult.bluesteel wrote:oh and 4.44 box, 20kg centre diff and front and rear tight clutch pack LSD's should get you out of trouble
And I'm going with a Torsen in the front diff.
Taken from here - http://www.bmsc.com.au/forums/buy-sell- ... g-box.html
I am listing this on behalf of a friend, a 5 speed WRX dog box. It has an Albins dog engagement straight cut gear set. The ratios are:
2.67/1.94/1.43/1.17/1.00 with a diff ratio of 4.11. The box includes an STi plated front LSD and STi 20 kg centre diff.
He is after $5000 (the LSD and centre diff are worth this alone)
Done one event since strip down and freshen up.
Contact Glenn Brinkman (in Qld) on 0414674 498
Posted pretty early this year but it could be a lead
And more stuff of interest here - http://www.rally.com.au/usefulinfo/forsale/id=1302
- brumbyrunner
Thanks for the link Wilbur but I've already seen it. Those ratios do not suit my tall tyres. Both of the aftermarker gearset manufactures that I know of in Aust, PPG and Albins, only make highspeed gearsets like the one in that link. I'm sure they are terrific but I'm holding out for these ratios.
3.454 2.333 1.750 1.354 0.972
They are the shortest factory gears that I know of. Never available with a 4.44 so has to be changed.
Found in 93, 94, 95 & 96 WRX-RA amongst others.
And those limos would only be worth that new.
Keep looking though! There's another team shirt in it for you.
- brumbyrunner
I have. They are big, heavy & expensive.
I don't think I need the extra strength yet but when the time comes I'll probably go for a 6 speed over a 5-speed dogbox for the same money. You can get 4.44 diffs for them and also a variety of traction aids.
A gearbox has become available. Can anyone tell me the ratios of it?
TY754VB5AA
TY754VB5AA
Those ratios you want are from -
JDM Impreza WRX RA MY93 TY752VB3BA
3.454 2.333 1.750 1.354 0.972 4.111Viscous (4kgf)Open
There is a good list of stuff here - http://spda-online.ca/modules/tinyconte ... tc_28.html but I couldn't find that other transaxle code
This you probably already know - http://www.albinsgear.com.au/images/pro ... sync96.pdf
- brumbyrunner
- brumbyrunner
Well I'm no closer to being mobile.
Just could not repeat could not get the stub shafts to pop out of my 3.7 plated rear diff. I then settled on installing an open centre to replace the non-fuctioning viscous limo just to get up and running. But the stub shafts are different between viscous and open so I tried to rob some out of another spare 3.9 open diff out of a Brumby and snapped the stub shaft while trying to remove the DOJ from it! As in snapped it right where the roll pin hole is.
Then I gave up for the day.
Bring on my built gearbox and diff. I have a Suretrac front, 20kg centre, 4.44 front ring & pinion, 4.44 rear ring & pinion, plated rear lsd and a workshop all ready to do the building.
All I need is the right gearset and a case and I'm in business. You wouldn't think that would be too difficult would you. I've been all over ebay, rexnet, bmsc, rslib, ozlib and gtrydaz.
- Outback bloke
- Outback bloke
- brumbyrunner
- Outback bloke
- Outback bloke
Eventually it would. It becomes an expensive exercise if you don't get the gear set right from the start. Best bet is to run a standard box in the ratio closest to what you think is right and then work out what you need to change before you buy a strong set of gears.
Brumbyrunner may find that the low ratio box fitted with a 4.444 diff could be too low, or then again he may want lower. You can buy turbo boxes for around $750 to $1200 in varying ratios compared to $4000+ each time you change ratios with an aftermarket set.
A possible box could be 1st and 2nd out of one box (you have to change both as they are on the input shaft and can't be swapped) with 3rd, 4th and 5th from other boxes.
