Building a car
Post by Subafury » Sun Feb 03, 2008 10:43 am
oh my that is a big list to complete in a short amount of time, ill come help out when i can
SUBYDAZZ
Post by SUBYDAZZ » Sun Feb 03, 2008 7:47 pm
AndrewT wrote:BTW please post up stuff I've missed! :)
I don't know much about doing these new-fangled engine converiosn things, but somewhere between these 2 points:
AndrewT wrote: - Drain the oil and put on a new oil filter....
.....- Make sure engine starts and runs
Please replace the sump plug and put some oil in it. :)
Looking at the timeline of this project I guess it's a case of not wanting to go too hard too early :)
Good luck with it in any case and keep us posted.
SUBYDAZZ
Post by AndrewT » Mon Feb 04, 2008 11:06 pm
haha yes I will put some oil in.
**Progress update.
Tonight I started prepping the engine bay for respray.
Got the front part in primer.
http://members.iinet.net.au/~carine3/IMAGE_00001.jpg
Edit - also picked up some more parts today.
- new front disc rotors, slotted
- new ball joints
- some new EFI hose
- I ordered a new water pump for the EJ20, just incase the one in there is worn
Post by AndrewT » Wed Feb 06, 2008 1:16 pm
Picked up the new water pump and gaskets from Subaru this morning. Also got a new thermostat and some rocker cover gaskets (there is some oil around there on the motor). The pump was surprisingly cheap, only $112.
The tailshaft is in at a local tailshaft place getting shortened, uni joints checked and replaced if necessary, and balanced.
I've ordered a new turbo front driveshaft (I only had one good one in the shed).
Soon as I get this driveshaft I'll be able to slap the front end together (Install Lib power steering rack, replace wheel bearings, install new discs, put in new ball joints etc).
BrennyV
Post by BrennyV » Thu Feb 07, 2008 9:43 am
moving at lightning pace atm andrew. so your not going to run the stock rx alloys? :(
Hunter S. Thompson
Post by AndrewT » Thu Feb 07, 2008 11:05 am
I will run the stock 13" RX alloys to pass it over the pits but then I'll get rid of them and change to 14" Sunnies (as I have a spare set). RX's look awesome with those fitted at standard or lowered ride height.
Later if I go Crossbred I'll just have some kind of WRX mags I expect.
Some more progress;
Bit more engine bay now in primer. It's tough work getting rid of 22years worth of oily grime and residue!
This morning picked up 4litres of white paint to eventually do the whole car in. Changing the colour slightly, no more Subaru "Milky White". It's now getting Subaru "Arctic White" which has a very subtle hint of blue in it as standard - very crisp and bright.
Also this morning I've put a standard EA82 radiator (Thanks Matt!) in to the radiator place to get upgraded to dual core, brass tanks and correct size/angle inlet and outlet pipes.
I've got a few current pics to post a bit later.
Post by AndrewT » Mon Feb 11, 2008 1:02 am
Only got a few hours into her this weekend.
Progress went backwards on the engine bay respray, discovered I'd been using the wrong kind of undercoat, had to strip it off using thinners. No biggy, my surface prep is still intact underneath. I'll spray the right stuff on again shortly.
Installed the 4.111 Viscus LSD in the rear end.
Separated the EJ20G from the frontcut's crossmember and control arms etc. I'll get it on the engine stand and get to work installing the water pump hopefully tomorrow. I'll be doing the timing belt too while I have the opportunity.
Bumpty
Post by Bumpty » Mon Feb 11, 2008 12:16 pm
This should be in the My Rides section ;)
BrennyV
Post by BrennyV » Mon Feb 11, 2008 12:55 pm
its not complete, so its no ride :P
Hunter S. Thompson
Post by AndrewT » Mon Feb 11, 2008 1:37 pm
Yeah was originally just floated as an idea - by all means, somebody move it to a more appropriate place!
Post by Subafury » Mon Feb 11, 2008 7:22 pm
lol there was no MY RIDES section when this thread was created
Post by AndrewT » Mon Feb 11, 2008 11:48 pm
Progress tonight;
Moved the motor into the garage and put it onto the engine stand. Cracked the crank pulley off and removed the timing covers.
I've removed the timing belt and water pump, got new ones to replace these with.
The crank pulley oil seal appears to be leaking slightly so I'll get a new one tomorrow. The toothed idler pulley bearing seems quite marginal so I'll get a new one from Subaru tomorrow too (ouch...I think these cost about $100!).
RX eagerly awaiting her new motor...
http://members.iinet.net.au/~carine3/IMAGE_00006.jpg
mmm Quad cam goodness...
http://members.iinet.net.au/~carine3/IMAGE_00011.jpg
New and Old water pumps...
http://members.iinet.net.au/~carine3/IMAGE_00012.jpg
Matatak
Post by Matatak » Tue Feb 12, 2008 12:30 am
2 and a bit more weeks to go Andrew :D
what are u doing about the Wiring. gonna copy the Wagons Loom??
get a Timing Belt Kit. aftermarket one. is heaps cheaper and has the idlers and seals included. MUCH better value. not worht going genuine i dont think.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Tue Feb 12, 2008 1:02 am
Yeah I am doing the timing belt, got a Daico one. Not worth getting the full kit in this case as all the idlers are fine except one.
Wiring loom I'm going to try and do myself copying the wagon's and WackyBug's one. Might need some pro help on this but I'll see how I go.
Post by AndrewT » Wed Feb 13, 2008 1:34 am
Got some bits and pieces this afternoon;
Shortened and balanced tailshaft - all uni joints in good condition.
http://members.iinet.net.au/~carine3/IMAGE_00013.jpg
Customised dual core radiator
http://members.iinet.net.au/~carine3/IMAGE_00014.jpg
Picked up a new front driveshaft so I have a pair brand new now.
Ordered the new idler pulley and some more seals etc for the motor from Subaru, have to wait for them to be sent from Sydney, hopefully arriving tomorrow afternoon.
Progress tonight;
Decided to assemble the front end components...
Before - Very manky, rusty, grubby front hub assemblies.
http://members.iinet.net.au/~carine3/IMAGE_00017.jpg
http://members.iinet.net.au/~carine3/IMAGE_00018.jpg
After - all cleaned up, new sealed bearings, new slotted rotors, new driveshafts, new ball joints, even new castellated nuts installed :) Did both sides tonight.
http://members.iinet.net.au/~carine3/IMAGE_00015.jpg
http://members.iinet.net.au/~carine3/IMAGE_00016.jpg
BrennyV
Post by BrennyV » Wed Feb 13, 2008 10:08 am
looks like your making some fast progress. are you going to running slotted on the rear also? hows the sexy rear brakes looking :P
Hunter S. Thompson
Post by Alex » Wed Feb 13, 2008 2:00 pm
give us a shout if ya need a hand!
PeeJay
Post by PeeJay » Wed Feb 13, 2008 4:50 pm
Put a new rear main seal in as well while you have the engine out, you'll curse when it leaks later on!
Post by AndrewT » Wed Feb 13, 2008 7:23 pm
Good point....I should add one of those to my Subaru order, forgot about that!
Hey PeeJay do you have a list of the specs of your RX and a bunch of cool photos?
I've been having trouble getting heaps of lovely pictures of RX turbos to inspire me!
Post by AndrewT » Thu Feb 14, 2008 12:41 am
Did some more tonight.
Some seam welding in the engine bay...made abit of a mess of this but it's comming up fine with a fair bit of work with the grinder. Should be alot stronger than the standard Subaru spot welding!
Fitted the power steering rack.
Thanks for the help from Subafury & Matatak.
Return to “AndrewT”
