WackyBug
Benny yer thats just a single range 4spd that was lying in my yard (Tristan you lazy bastard!). Using it as a template to make the plate.
I couldn't be bothered removing the dualrange 4spd from Buggy, may aswell leave it in there and just fit the motor to it when I'm ready.
Yer at most I'll test drive it up the cul-de-sac for a while....but shes definitely not going offroad until the roll cage is welded in.
Just picked up the clutch today and got a metric tap for doing the threads on the adaptor plate.
Might have a crack at fitting the motor this arvo then.
Nah its okay - put her on a flat road and she's straight.
But yeh, no offroading until theres some bracing!
brace it with bouble wrap.
Dave
Dave
BAHAHAHA!El_Freddo wrote:Or maybe you could wear those bubble wrap suits like in "dude where's my car?"
ZOLTAN! *does Z hand signal*
More progress tonight...
Picked up the new clutch plate and beefed up pressure plate this afternoon.
http://members.iinet.net.au/~carine3/IMAGE_1.jpg
Drilled and tapped the top holes into the adaptor plate.
http://members.iinet.net.au/~carine3/IMAGE_4.jpg
(That's the metric tap in one of the holes).
Here's the adaptor plate and clutch all bolted up on the motor, nice and tight.
http://members.iinet.net.au/~carine3/IMAGE_2.jpg
Clutch all alligned and ready to go.
I ran out of time tonight otherwise I'd have dropped the motor into the buggy's engine bay. It's ready to go in anyways!
anything gold is classy..username wrote:"STI" spray painted on the radiator is a touch of class...
lookn good mr T
Yes, Gold and Mr T are the definition of class
http://www.narniaweb.com/forum/uploads/ ... 9_Mr_T.jpg
More progress on WackyBug...
The engine is now in the buggy and all bolted up to the gearbox. Here are some pics;
http://members.iinet.net.au/~carine3/IMAGE_10.jpg
http://members.iinet.net.au/~carine3/IMAGE_11.jpg
http://members.iinet.net.au/~carine3/IMAGE_12.jpg
http://members.iinet.net.au/~carine3/IMAGE_98.jpg
http://members.iinet.net.au/~carine3/IMAGE_99.jpg
I didn't take a trace, and to be honest my plate hardly followed the pre-marked texta lines at all. It's easy to make one with no template at all, all you need is the EJ engine, EA gearbox with flywheel and use them as a template. Best to do it that way for maximum accuracy.
Wiring harness is 85% complete.
I know u said u wanted buttons and switches on the dash for the ignition but there may be a problem beacause they would all have to be water proof. Wacky doesn't really offer much moisture protection.
Dave
Dave
Cool thanks Dave.
Yeah I will most likely buy some nice waterproof toggle switches from d1cky Smith or something. (Altho Devil Dave apparently already bought all these ages ago, I'll have to find out).
