Sti in a brumby
Sti in a brumby
Hey guys I have done a bit or searching with no luck in just over a month I am planing on doing an eh conversion to my brumby I don't want to hack the chassi rails but I want something more powerfull than an ej20 my thoughts are getting an 96 wrx ej20g removing the turbo and supercharging it but 1 I am not sure how a turbo motor will run with a supercharger and 2 I am not sure if this motor will fit between the chassi any help would be greatly appreciated and any better suggestions would be great (I realize this is an expensive projects I am willing to put the money into it)
[SIGPIC][/SIGPIC]88 Brumby
89 Legacy gt turbo
97 wrx (wrecking)
89 Legacy gt turbo
97 wrx (wrecking)
- TOONGA
EJ20g is a twin/quad cam motor, it would need the chassis rails and the crossmember to be modified for it to go in.
look at this thread started by Subarino in 2007, he used an EJ22 but a single cam EJ25 would work as well.
showthread.php?t=7699&highlight=supercharger
the car is still running and now owned by 90brumby.
good luck with it
good luck with it
- d_generate
Why would you take a perfectly good well designed turbo off an engine it was designed for and spend god knows what trying to squeeze a frigging supercharger in an engine bay the size of a matchbox, if you want better early response put a twin scroll set up on it.
12lb of boost through a stock high compression 2L..........I'd like to see that last more than a week, even the early low compression EJ20's were limited to about 12lb
Here is an STi EJ20 in a Brumby, standard height
Note the treatment from a power pack or BFH ? No cutting, no welding - just a massage
Uploaded with ImageShack.us
i put one in without modifying the rails. the timing covers touched both rails, but never had any damage in the 20odd thousand kms it was driven hard
davo
davo
- Dean.nabbe
hi guys. i'm new to this but i am interested in doing a similar conversion... i'm not much of a mechanic, i'd rather find the parts and pay someone to fit it for me...
i have a 1987 Brumby with a 4 speed manual. i have heard that an impreza motor will fit straight in(wiring required obviously) what year model would i be looking for or what engine?
also will the 5 speed gearbox for that motor fit in without any mods?
any help would be appreciated..
thanks
thanks
- Dean.nabbe
For what its worth, there is nearly always a turbo brumby on ebay or gumtree. Just buy one that is 90% complete and finish it. Will be cheaper in the long run if you are gonna pay a mechanic to do it.
- SUBIIE
read my thread in my sig to see wha ti needed to do.
I never should have cut the rails. Luckily the engineer passed it.
