EJ20T stalls out on gear change
Any thing and every thing ever asked about how to do an EJ conversion to an L series and MY. Includes Brumby and Coupe.
SUBIIE
Post by SUBIIE » Tue Dec 04, 2012 11:57 am
Hi Team,
ej20t GC8 in a brumby, pod filter.
On deceleration, lets say to a set of lights, the engine will stall out between gear changes if I dont make them quick enough. But if I roll in slowly and are quick in down shifting then there are no problems, car will happily sit there at 800 rpm idle.
Any ideas?
woody.t
Post by woody.t » Tue Dec 04, 2012 1:01 pm
AFM/TPS possibly... have you ran a diagnostic on it?
also seen issues in other car types using after market air filters if they shorten the track too far from the standard intake length
to do list:
Post by Gannon » Tue Dec 04, 2012 2:52 pm
Do you have an atmospheric venting blow off valve? This will cause issues because the air flow meter calculates how much air is drawn in and injects the required fuel, but if part of that air is dumped through the blow off valve, the same fuel is still injected and and makes air/fuel mixtures extremely rich for a few seconds, making the engine stall
Post by RSR 555 » Tue Dec 04, 2012 6:57 pm
Gannon wrote:Do you have an atmospheric venting blow off valve? This will cause issues because the air flow meter calculates how much air is drawn in and injects the required fuel, but if part of that air is dumped through the blow off valve, the same fuel is still injected and and makes air/fuel mixtures extremely rich for a few seconds, making the engine stall
+1
This was my first thought. I'd be checking for error codes ;)
SUBIIE
Post by SUBIIE » Wed Dec 05, 2012 2:20 pm
ok, all a bit over my head despite doing the conversion myself.
The AFM is still there, I just put the Pod filter on where the air box attached.
That was my thought originally.
No fault codes coming up apart from the check engine light coming on when doing a long descent and not using the throttle at all using the engibne to break the car.
Could the AFM be faulty, or is it more likely to be the change in flow from the pod?
Return to “Fitting EJ motors to MY & L series models”
