Conversion advice
Conversion advice
Here we go
Flame me if must be.....but....
Where can one purchase the conversion plate to fit EJ20 or EJ22 to a MY 5 speed gearbox mated to an EA81 currently in a Brumby.
Peter
Peter
Makeone
Make one needs to be 12mm thick I'm pretty sure just use the box/engine as a template. Or get one from byb but apparently sometime you have to mod them anyway so I have read.. There are threads out there I was reading one just the other day
Read heaps but no-one actually namesa a manufacturer.Yarran wrote:Make one needs to be 12mm thick I'm pretty sure just use the box/engine as a template. Or get one from byb but apparently sometime you have to mod them anyway so I have read.. There are threads out there I was reading one just the other day
M Rose but when I looked at the page it was camping gear.
Makeone
I like your thinkingsteptoe wrote:whack up a want thread, likely to be nfinished projects sitting about or someone finally gone full EJ box as well.
As for MY5 speed - they were only FWD. You must have L Series 5 speed 4WD box ?? Sometimes refered to as a 10 speed by one car magazine back in the day
while we r at it will a 5 speed off an EA82 bolt up
- TOONGA
nope you will still need an adaptor plate. the other course of action is to get a forester 1:47:1 dual range box and matching diff (must have male stubs or the female cvs ) then make your own gearbox crossmember.ozbrumby wrote:I like your thinking
and the gods answeredsteptoe wrote:whack up a want thread, likely to be nfinished projects sitting about or someone finally gone full EJ box as well.
well the for sale section did anyway
what did you get yors hands on?
howd you go>?ozbrumby wrote:and the gods answered
