Fitting an EJ Motor into an MY or L Series Subaru
Posted: Tue Jan 03, 2006 12:14 am
Hi,
This thread has been started to fill a gap missing since the old board. I am going to cover the basics of fitting the EJ series of motors into the older MY and L series Subarus. This is by no means a complete guide, it is more of an overview of the project.
Newbies should read through all this info before asking questions as starting a new thread. While we really do love to help, getting asked the same questions over and over is a little tiresome.
First of all I'd like to clarify for those out there what each of these is. An MY is a Subaru originally fitted with an EA71 or EA81 motor, this includes all coupes, sedans and wagons from 1979-84 and all second generation Brumbys (1980 on). An L series is a sedan or wagon produced between 1985 and 1994. There were other body styles produced, but we are focussing on the Australian models here.
Secondly I'd like to distinguish the variants of the EJ series of motors. They are a wide and varied series, ranging from the 1.5 litre EJ15 up to the 2.5 litre EJ25. There are multipoint injection motors (MPFI) and single point injection motors (SPFI). There are single overhead cam motors (SOHC) and double overhead cam motors (DOHC). There are also turbocharged motors, in Australia and Japan these are all DOHC. These are often reffered to as EJ20T's, in actual fact this motor doesn't exist. The first EJ20 turbo motor was the EJ20G, and there have been many model codes since, such as the EJ20K, EJ20R, the EJ207 and so on and so forth. There are minor differences when converting too, Subaru have fitted many different heads, manifolds and turbos to each model.
Also, I am assuming in this guide the use of a manual gearbox. I have no experience with EJ automatic gearboxes, so I'll leave that to someone more in the know.
The Basics of fitting an SOHC EJ motor to an MY:
This process is rather straight forward. Any motor up to the EJ22 can be fitted without modification to the chassis rails, the only potentially structural modification to the body would be the slotting of the holes in the engine crossmember where the mounting studs slip through. I beleive to fit the EJ25 motor there would need to be major modification to the chassis rails, more so than the turbo motor (see below).
The engine crossmember needs to be spaced downwards about an inch and the steering linkage modified to suit for bonnet clearance. This is not necessary on a lifted vehicle. This will make your camber more negative and flatten your front CV angles.
The radiator outlets will need to be modified to suit the larger hose size, but the radiator should be OK for cooling capacity.
The exhaust will need to be custom built, a good setup is to use the factory EJ exhaust headers and then custom pipes from the centre back. You could also modify the exhaust headers to fit your standard system.
The best way to do the wiring is to take the entire EJ engine loom and trim it down to suit your needs. You'll need to keep all the engine sensors and devices, wire up a check engine light and spider the harness into your vehicle. Most find this to be the most difficult point.
If fitting the matching EJ gearbox, you will need to use custom inner CV joints to mate to the larger splines on the EJ gearbox. The gear linkages will need to be shortened slightly to fit in the right spot. Some people have opted to use an EA gearbox, this requires an adaptor plate and slotting of the EA flywheel to mate to the boss on the back of the EJ crank.
If using an EJ AWD gearbox the tailshaft must be lengthened 120mm to accomodate the shorter length of the box.
A matching rear differential must be used.
The fuel system needs to be brought up to EFI spec. Most people use a Bosch fuel pump from a VL Turbo in conjunction with a surge tank. A return line must also be plumbed through the vehicle.
The Basics of fitting a DOHC EJ motor to an MY:
The process is mainly the same as for the SOHC, but with attention to the following points:
The chassis rails will need to be cut & reshaped to clear the timing covers.
If fitting the turbo motor also, the crossmember must be modified to suit the up-pipe on the turbo. Alternatively a turbo crossmember can be used, provided it is from the same model as the project.
Realistically the only gearbox that should be used is the matching turbo gearbox. These use a much stronger pull-type clutch.
The Basics of fitting an SOHC or DOHC EJ motor to an L series:
The process is mainly the same as MY, but with attention to the following points:
The engine mounts will need to be spaced upwards with washers, the L series has a slightly different angle on its engine crossmember than an MY.
The entire EJ series of motors can clear the chassis rails. No modification needed.
There is a difference with the tailshaft in an L series. I have heard it needs to be lengthened 70mm, although I can't confirm this at the moment.
I'm sure I've missed some things, and if you see any errors please point them out.
