Page 7 of 7
Posted: Thu Apr 14, 2011 8:24 pm
by TOONGA
Posted: Thu Apr 14, 2011 8:42 pm
by Gannon
GOD wrote:
EJ16s and EJ18s don't have a cam sensor or a knock sensor. Don't think they had any ECU control of the EGR gear either.
Actually, i think this may only apply to single point fuel injected models.
Posted: Thu Apr 14, 2011 9:21 pm
by BaronVonChickenPants
Sorry, meant to post this earlier but got distracted by something shiny (*cough* Gran Turismo 5 *cough*)
This is everything I have from when I was doing my EJ18 conversion, I was told the EJ16 was the same also.
FSM Scans
I have most of them in high resolution if you need it.
Jordan.
Posted: Thu Apr 14, 2011 10:48 pm
Jordan ! You've moved again?
Thanks guys I shall have a look in time at the links.Hey even my 86 4GLTA ECU 3 plugger has some EGR control, well it is suppose to not operate below a certain temp or work above a certain speed. It does not have these limits - works all the time.
The donk came out of a crashed Impreza 1996 under yella oil cap - got the loom and ECU expertly removed by Damo666 and donated to a good home
Posted: Fri Apr 15, 2011 1:40 am
by GOD
Suparoo wrote:Actually, i think this may only apply to single point fuel injected models.
Nope, all (four?) the Australian MPFI EJ16/18s I've looked at have been like this.
Posted: Tue Jan 31, 2012 7:15 pm
by B00sting
Anyone know if you can lift a brumby (93) to avoid chassis rail modification when dropping a DOHC ej25 in?
If so how much is needed?
Posted: Fri Feb 10, 2012 4:28 pm
by yarney
B00sting wrote:Anyone know if you can lift a brumby (93) to avoid chassis rail modification when dropping a DOHC ej25 in?
Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.
Have a look at 92 brumby he has only got a SOHC EJ20 in it and it goes well even with 30" tyres.
Jan
Posted: Fri Feb 10, 2012 7:53 pm
by B00sting
yarney wrote:Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.
Jan
Actually I'd just like an answer to my question if possible
Does it matter what I want? It doesn't effect anyone else....
Cheers.
Posted: Mon Feb 13, 2012 4:43 pm
by AndrewT
Tim (the opening poster of this thread) had a 4" lift in his MY wagon at one point, still needed the rail mod to fit the DOHC motor.
It's only a minor mod, not structural, easy to do and if done well - not obvious to look at. If your heart is set on a DOHC motor, just do it.
Posted: Mon Feb 13, 2012 9:13 pm
by 90brumby
i reckon with the 6inch lift i had in my car the DOHC would have fit but if you want dohc just do the rail mod like andrew said
tristan
Posted: Sun Mar 04, 2012 7:18 pm
by B00sting
Is it any easier to fit the early ej25s (e.g outback 99) versus the 2006-2010 forester engines?
I can get a 2010 motor for a good price is all.
fitting a ej25 to a 82 my
Posted: Fri Jun 22, 2012 8:30 am
by Scheffer1986
Has anyone fit a ej253 sohco into a brumby/my wagon ?
Ideal donor car for EJ conversion?
Posted: Thu Jul 11, 2013 10:08 am
by ajcmbrown
While pondering an EJ conversion, it dawned on me that there must be an "ideal" donor car for the job, not what is possible, but for example, what would be the best use of the parts available from just one car without cutting chassis rails etc, Forester two litre EJ with manual D/R g/box, so that I can use drive shafts, diff assy, wheels, brakes, steering column etc.
Is this feasible in just one model?
Am I being overly optimistic in thinking that I could do a drive-line update without having to make major modifications like fitting an EJ25 for example?
My old Brumby that I have on the farm (2 actually) which I am contemplating putting on the road would be a lot more enjoyable if it were for example a EJ20-EJ22 N/A manual D/R gearbox with matching rear diff, drive shafts, upgraded brakes, front suspension?, etc.
What model would give me the best "bang for my buck" if I were to buy just one donor car?
I would think that there would be others who would find this interesting before deciding on an engine/gearbox combo that could need extra parts to be sourced from different models.
Posted: Sat Jul 13, 2013 3:59 pm
I'm sure it's been done. Same as an EJ22 SOHC conversion pretty much.
Posted: Sat Mar 22, 2014 9:24 am
by ozbrumby
My 91 Brumby has a SOHC 2.5L in it with the AWD setup
Scheffer1986 wrote:Has anyone fit a ej253 sohco into a brumby/my wagon ?
Hi guys
Posted: Mon Nov 17, 2014 8:14 pm
by Alpinebarry
New to site and subaru world as such. Just starting my own El22 swap into my ea82 L series. Lookin for all the help I can get
Posted: Mon Nov 17, 2014 9:29 pm
by TOONGA
El freddos thread about his "L" series would be a good start
showthread.php?t=11733
my thread if you want to go carby and dizzy
showthread.php?t=15851
this PDF will help as well
downloads.php?do=file&id=134
Good luck with it
Posted: Mon Nov 17, 2014 10:40 pm
Barry,
I found that post of AndrewT's of how to make your own adaptor plate
here
Also,
this might be worth a read for you too.
I'll update the last link as I've done some new things that are worth knowing about in my opinion.
Re: Fitting an EJ Motor into an MY or L Series Subaru
Posted: Tue Sep 18, 2018 6:31 pm
by Willy Fisterbottom
*Engine
