Page 3 of 5
Posted: Sun Mar 24, 2013 12:25 am
by 60766244
guyph_01 wrote:Ok, It's done....
Yes i Know Paul......, You don't like it!!
Looks superb.
Posted: Sun Mar 24, 2013 2:45 am
by Wagonman
by help he meant boss me around. haha seriously though he just put a plastic bag over his foot and slid it into his boot (lesson learned perhaps?) and carried on as normal.
Sent from my GT-I9100 using Tapatalk 2
Posted: Sun Mar 24, 2013 12:48 pm
by RSR 555
guyph_01 wrote:Yes i Know Paul......, You don't like it!!
Honestly it doesn't look too bad but I'm not a fan of that bit that hangs down in the middle.
Posted: Mon Mar 25, 2013 4:07 pm
by guyph_01
Can anyone help me and tell me what ratio this box has? 64-TY752X1DCA
Thx
Posted: Mon Mar 25, 2013 5:37 pm
by RSR 555
guyph_01 wrote:can anyone help me and tell me what ratio this box has? 64-ty752x1dca
thx
4.111
Posted: Tue Mar 26, 2013 7:22 am
by TOONGA
Posted: Tue Mar 26, 2013 7:33 am
by guyph_01
Nice, So i don't need to find a rear diff for it anymore:)
Whats the easiest way/Steps to replace the diff on the Gen2, What are the bits i need to undo?
Thx
Posted: Tue Mar 26, 2013 7:52 am
by TOONGA
The nuts
the file below is for the TRANSMISSION AND DIFFERENTIAL SECTION for the 1998 outback
http://jdmfsm.info/Auto/Japan/Subaru/Le ... ECTION.pdf
page 191 tells you which diff you have, page 199 will give you an insight into how it comes out, and page 209 is the start of the procedure.
Posted: Thu Apr 11, 2013 9:10 pm
by guyph_01
Hummmm, What do you guys think?? does this mean the engine may have slightly over heated???? lol
Well The plan is to wack a set of head gaskets on the engine and see if it runs again:) Paul seems to think it will be fine and the trip from Joondalup to my place the engine ran better than expected and only stopped at the last minute!!
Also The previous idiot had thread lock the crank pulley and ohh god Paul battled to get that thing out...
NOTE: anyone got rear ej22 timing covers and a gen2 cam angle sensor locally?
Thx
Posted: Fri Apr 12, 2013 10:15 am
by RSR 555
Yep.. you need to bring some CCs.. I lost a lot of fluid trying to take that pulley off
Posted: Fri Apr 12, 2013 9:55 pm
guyph_01 wrote:NOTE: anyone got rear ej22 timing covers and a gen2 cam angle sensor locally?
Thx
Umm... There's something wrong here!
I've seen that cam cover melt before - on my EA82 that originally came in Ruby Scoo. That engine was a throw away for two reasons - 1) it was an EA82 and 2) cylinder #3 or 4 had a crack down the bore that you could catch your finger on. And this thing drove ok - felt like it really needed a tune up.
I would believe that the EJ is much better at "recovery" after being punished like this. But I've not had a direct experience with doing what you're about to do Guyph, I'll be interested in the outcome and hope it all turns out for the better.
If not I'm sure you won't have an issue rustling up another good EJ22
Posted: Sat Apr 13, 2013 9:53 pm
by guyph_01
Yes i know, I also wasn't to keen to put that engine back in the car. yes the plastic covers are melted but did you notice the oil seal??? I seen melted plastic covers before but never melted oil seals.
You know it's been about 5 years now that i joined and have been playing with subaru's ever since with you guys help. One MAJOR thing i finally learnt after all those years, When Paul shake's his head and says NO don't do it or no it can't be done, DON'T bother, no point trying.
And when Paul says yes it will work or yes it can be done, It always the case!!!...
So yeah, Paul said that he thinks the engine will run again, I think i'll listen:)
LOL
Posted: Sat Apr 13, 2013 9:55 pm
by RSR 555
Just thinking Guy.. maybe the EJ20 single and double OHC might use the same cam sensor??
Posted: Sun Apr 14, 2013 7:19 am
I like how Guy says the previous idiot - is he suggesting he is the current idiot ?
Ah, the bloody English language
I love it when speakers of English as second language tell me they are "having it off tomorrow" Is that a double entendre? ( pinching a French word I can't spell
I was thinking have only seen thse drooping belt cover backs on cooked EA82's and they must have been bloody hot for quite a while! Those seals did not melt did they Guy ? Just looks like leaking oil turned to grease from your pics
Posted: Sun Apr 14, 2013 11:08 am
by guyph_01
steptoe wrote:I like how Guy says the previous idiot - is he suggesting he is the current idiot ?
I meant the previous owner...
Need to ask Paul about the seals, he took them off:)
Posted: Sun Apr 14, 2013 2:57 pm
by Subydoug
Did you try a breaker bar to the chassy and hitting the starter motor to get the pulley off? Thats usually what I do
. Thats a mighty roasted engine. What did the oil inside it look like Guyph?
Doug
Posted: Sun Apr 14, 2013 9:10 pm
by guyph_01
Subydoug wrote:Did you try a breaker bar to the chassy and hitting the starter motor to get the pulley off? Thats usually what I do
Doug
No the bolt was easy to get out, What i meant was the crank pulley was thread locked to the crank shaft!!! Who does that???
Oil is black!! lol
So far all the lift blocks are made and installed on the car, I think it the first time i haven't cross-threaded a nut installing a lift kit. Paul will be proud!! LOL. Now i'll get the strut top draw at work and laser cut:)
Tomorrow i'll start to get the engine back in..
Posted: Mon Apr 15, 2013 9:23 am
by RSR 555
guyph_01 wrote:Well The plan is to wack a set of head gaskets on the engine and see if it runs again:) Paul seems to think it will be fine and the trip from Joondalup to my place the engine ran better than expected and only stopped at the last minute!!
Looking at the inside the engine appears to look ok, really won't know the extent of the damage the heating has done until we can do a compression test.
What you mean it stopped? you told me you turned it off when you got home and it just pissed out oil like it was water??
guyph_01 wrote:So yeah, Paul said that he thinks the engine will run again, I think i'll listen
It will run for sure but you will need to be on the look out for a replacement, as I can't say how long it will last.
steptoe wrote:I was thinking have only seen thse drooping belt cover backs on cooked EA82's and they must have been bloody hot for quite a while! Those seals did not melt did they Guy ? Just looks like leaking oil turned to grease from your pics
guyph_01 wrote:Need to ask Paul about the seals, he took them off:)
Very much like grease but the seals were that rock hard, they came out in pieces.
guyph_01 wrote:No the bolt was easy to get out, What i meant was the crank pulley was thread locked to the crank shaft!!! Who does that???
Oil is black!! lol
The Harmonic Balancer pulley was easy to get off, the problem was the Timing Crank Pulley.. this was a SOAB to get off !! and I'm still waiting to replace that lost fluid Guy??
Proud of you son.. now hurry up and get it finished
Posted: Mon Apr 15, 2013 10:35 am
by guyph_01
Yeah it turned off:)
Posted: Mon Apr 15, 2013 10:57 pm
by RSR 555
guyph_01 wrote:Yeah it turned off:)
LOL.. you know there was a concrete warranty on the engine?
