Brumby wrx convertion
Moderator: Rumbl1n
Still not sure about the lib rack fitting on the brumby cross member but if thats the case why don't you use the wrx rack and pump off your donor car and buy new rack ends?
ok guys i still have a few blank spaces that im not sure about...
I dont know what to do about c/v joints
Can anyone suggest what clutch i should run dont want some cheapy
And STILL have not found a diff really dont want to go to the wreckers an pay crazy prices
[SIGPIC][/SIGPIC]88 Brumby
89 Legacy gt turbo
97 wrx (wrecking)
89 Legacy gt turbo
97 wrx (wrecking)
sweet i think i need the wrx inners and outers on the brumby shafts because i am doing the brake conversion aswell90brumby wrote:Cv s if u go to allans cvs he can make the outer brumby joint fit with the inner wrx cv on which Eva length shaft you need
89 Legacy gt turbo
97 wrx (wrecking)
89 Legacy gt turbo
97 wrx (wrecking)
- TOONGA
If you are going to 5 stud (via the conversion kit) then as long as you have a rear diff in the car you bought then you are ok. another problem you will encounter is the tailshaft. you will either need to get a one piece made or make a 2 piece out of parts that fit. I used a wrx rear part (changed the diff flange) and a liberty manual front (from memory)
Any update to this? How'd you go with the dashboard?
- Green_eyed_liberty
- Proton mouse
