STUMBLED ACROSS AUSUBARU AGAIN!!
Moderator: FROG
- FROG
Hi guys
found the forum active again!
hit me up for parts at discounted rates
Subaru genuine parts, Subaxtreme products
Mazda Jeep Chrysler and Doge also
I will edit the current posts when I get time
regards FROG
regards FROG
Re: STUMBLED ACROSS AUSUBARU AGAIN!!
It’s been a while Frog! Awesome to see you on the forum again!
My activities have stalled but I reckon I’ll be back at it soon enough!
G'day and Welcome back Frog
I was curious as to what had happened to you when the Forum changed, now I know, you got left behind in the dust.
- TOONGA
Welcome back Mr Frog good to see you found us again
Do you like what we’ve done with the place, Froggy? And when I say we, I mean Andrew!
Hi Frog,
I'm new to the group, just bought a 1990 Brumby. I'm chasing gear linkage kit and engine mounts all around, Can you help me out?
Thanks
Russell.
Thanks
Russell.
Welcome to the forum Russell.
Read up on the gear linkage mod as this will probably be the issue if you have the original 4 speed. Halfway down this thread is how I did mine.
If you have a 5spd conversion, you’ll need the bushes for the knuckle joint in the selector arm/rod to fix the slop. My L series has a temporary fix using a piece of cut down garden hose from 2016... it’s still working well so I haven’t got around to replacing with the proper bushes.
Send Frog a PM, that might hopefully speed up his reply if he’s not out quad biking atm.
