Page 1 of 2
Posted: Tue Aug 11, 2009 8:23 pm
by scoobymine
They look great, what are they off? How much did u pay. know what u mean about drums, having problems getting seal kits and cylinders for mine. Swapping to disc looks a great idea
Posted: Wed Aug 12, 2009 7:18 pm
by TOONGA
they are off a 89 l series touring wagon and cost $400 Im really lucky as the rotors and disc pads are near new, (and are in reality as rare as hens teeth well the hubs are) you might want to talk to andrewT as he has a set but Im not sure what price he wants
Posted: Sat Jun 26, 2010 4:22 pm
Just familiarising myself with this post, and drag it up again to the top.
Need to find myself a 10mm pipe spanner and the bleed sequence for Brumby, (where's my bloody manual?!) before I start my Pick-n-Pull Portland North, Oregon 97203 conversion.
Julian, an estimate of the time it took you including the dramas per side ? may also be helpful
I also notice that there is still what looks like another backing plate behind the caliper mounting plate. Is that normal to 1. even be there 2. to stay there (asks he too lazy or in a hurry to look at his own Brumby
Posted: Sun Jun 27, 2010 4:31 pm
TOONGA wrote:they are off a 89 l series touring wagon and cost $400 Im really lucky as the rotors and disc pads are near new, (and are in reality as rare as hens teeth well the hubs are)
Toonga - they're originally from an RX turbo L series. The only touring wagon they would've come from factory was the GT2 like what Chris Rogers started out with for this twin turbo psycho Touring wagon conversion...
I've got the same on Ruby Scoo - I'm glad I do as the braking system with the disc/drum combination with the EJ would be outright dangerous! The discs all round, while still L series spec are much better suited to the EJ conversion application, I'd recommend anyone doing an EJ conversion to upgrade the brakes to either L discs all-round or Crossbred conversion which would be the ultimate way to go. I might end up with something like this some day...
Posted: Sun Jun 27, 2010 4:59 pm
by TOONGA
Bennie yes they are probably off a sedan but the guy had them on an L series wagon
Steptoe no second backing plate there Ive even looked at the pictures I didn't post to see what you mean .
it took about an hour a side with electric tools, the biggest problem I had was getting the brake drum mounting plates off but a big hammer took care of that.
and not having a proper set of jack stands definitely made working on the car very un-safe
Posted: Sun Jun 27, 2010 10:06 pm
Julian, the last image in post #6 with the brake fluid on the pavers distinctly looks like a second backing plate or dust plate behind the calliper mounting back plate. Have since looked at mine and there is just a drum backing plate which will go.
Thanks for the times guide too.
Thinking I should do a stopping distance test first without attracting too much attention
Likely to go mad looking for my gregories for the Brumby bleed sequence. Not starting 'til I find it either
Posted: Sun Jun 27, 2010 10:38 pm
by RSR 555
Jonno.. I'm not sure if there is a sequence or not but I follow the old rule of the furthest away from the Master Cylinder first.. so it would go like this.. LHR, RHR, LHF and lastly RHF and then I go back and do it a second time
Works fine for me everytime
Posted: Mon Jun 28, 2010 8:10 pm
Brumby and MY bleed seq as per Gregories
1st RIGHT REAR, FRONT LEFT, LEFT REAR, RIGHT FRONT
It is different to L Series bleed sequence.
Once seen Lasers with similar bleed seq did not like furthest wheel from master as starting point, next furtherest and so on, so being cautious here.
More good info on torque setting for the bolts M10 1.25 pitch for backng plate to hub arm and calliper to backing plate. If bolt has 7 on it ( I assume it is same as 7T) - max of 40Nm (27 ft lbs) from subie manuals based on bolt size, pitch and 7T, 9T etc
Now, oddly my RHS backing plate bolts had a 9 on them, they get a max of 54Nm (40ft lbs)
I also managed to confuse backing plates when I went to mark one as L for left. I managed to fit it to the RHS, torqued up, next the rotor and hub, the calliper carrier bolts too think and something was definitely wrong, even my second attempt failed due to the backing plate not marked as L or R on dismantle ( I blame the factory I really do ) notr were they marked for the odd sleepy head for inside outside either.
I got the L on the right side with calliper cut out in correct position but wrong way out. Third go with correctly marked plate, I got it right. When I tried to copy same error on the left with a photo shoot in mind on how not to do this - it would not line up with holes etc yet right jhand side did. CONFUSED? I WAS !
Posted: Sat Jul 03, 2010 11:21 am
UPDATE report:
I am so impressed with the performance upgrade of the L Series rear discs on my Brumby. In the dry it feels like the fronts are not under so much pressure or stress to perform 75% or more of the vehicles braking duties. The rear discs are sharing the load so to speak. Wondering what drum brakes did ! I always nicked my drums up at oil changes or before a trip. They were machined and new shoes some years ago but show little evidence of work - as there was stuff all wear in over 100.000km.
We had some light rain last night so took it out for a gentle work up
It was like I had also fitted ABS brakes - no kidding. Not as in brake pedal sinks to floor when ABS at work but I can jump on brakes that are now reluctant to lock up but allow all four tyres to grip and slow me down a hell of a lot faster, usually in old factory disc drum, fronts would lock up and slide, no control until pressure released off pedal. I was able to brake and steering safely left, right and back again, repeatedly at speeds of about 70 - 80 kph in the wet, kangaroos abounding etc.
Tried the brakes s I turned into corners - not something I usually need to do but this thing was so sure footed
Ever since Volvo fitted disc brake rears, in when late 60's ?, the driving consumer should have knocked back drums on rear in show rooms. I was disgusted to see early Imprezas stil had drum brakes.
Anyone who has worked with or on drum brakes would vouch for how archaic they are in their componentry and service and inspect and just how crap they can be compared to disc caliper set ups. ADR's should have outlawed drum rears with pollution control in 1976 - at least !!
Posted: Sat Jul 03, 2010 12:13 pm
Posted: Sun Jul 04, 2010 12:22 pm
Also noticed the body to trailing arm rubber brake hoses have external cracks. Likely to be originals fitted in 1984 so deserving of renewal for safety sake. Often it is cracked hoses that pass rego until they actually start to weep, but having had a nn weeping external crack hose go on me suddenly at low speed - it was no fun. Have found aftermarket hoses made up by brake places a pain. Need a sample and then the original clips not fit the hose, return trip to get badly fitting clips - to save about $15 a hose. This time i have ordered genuine at about $50 each - expecting smooth replacement (other than get brake fluid ooze down sleeves in winter)
Disc Calipers,hubs,Rotors for rear Brumby
Posted: Tue May 28, 2013 10:12 am
by Gazza01
Hey Toonga. I got a pair of Tokico CL-9T (Same as yours)rear disc calipers from Rockauto.com in the US for $174 both remanuf. postage was a shocker, and ive got a pair of Vortex XT rotors RDA7554 from Aust. Now Ive found a pair of well used rusty looking rear hubs from a wrecking yard in Penrose, Coldorado USA. They are off a 4x4 turbo Vortex 4cyl, No where in Australia could I get this stuff. Tried wrecking yard in Aust & NZ etc. Just a stroke of luck I found these two hubs on Ebay.pretty rusty looking. Cost $35 each. Have to get them here via a shipping agent and its gonna cost me. Does it look like Im on the right track, with this stuff. Im holding my breath with the hubs and hoping the hub holes match the RDA7554 hubs and the rear stub axle. All ive got to do is find or remanf. a backing plate. This is all for my 91 Brumby ute.
Posted: Tue May 28, 2013 10:57 am
Spend more time in here and you will find they pop up.
It may help if you research the USPS flat rate boxes for shipping and encourage US supplier to use them, 'just' needs a customs form filled out, some stuffing to protect contents and takes 7 to 10 days transit. These then get tracking and sign for treatment by AusPost once in Australia.
My shipping agent is still holding my stuff and waiting for a ransom note
any time soon
Posted: Tue May 28, 2013 6:46 pm
by dfoyl
Last set I imported cost about $200 in postage plus $150 for the set. Went to a board member here, a lot cheaper than $500 from JY's or eBay here still...
Re: Fitting disc brakes to my Brumby
Posted: Tue May 21, 2019 1:59 pm
by TOONGA
adding photos slowly to fix photobucket stupidity
