Bantum's '82 Touring Wagon ...
Moderator: Bantum
Refills ...
Post by Bantum » Sun Aug 23, 2026 4:53 pm
Ready to top up fluids :
Also got round to installing this :
Still need to hook it all up :
Loads more to do still - Bantum ...
Re: Bantum's '82 Touring Wagon ...
Post by El_Freddo » Sun Aug 23, 2026 11:36 pm
Looks good mate, weird looking pump. I assume it’s a low pressure pump.
There’s always loads more to do!
Your effort with your rims looks amazing!
Spun out ...
Post by Bantum » Wed Aug 26, 2026 1:56 am
Yep - its a low pressure pump - old one was kaput ... ;p
Speaking of wheels - I spent a few hours getting these bad boys ready & rust free :
Couldn't get the 'yellow' colour same but : ( re-zinc chromed )
Awaiting a few more parts to finish ...
Cheers, Bantum ...
Wing Mirrors ...
Post by Bantum » Wed Aug 26, 2026 2:02 am
Also spent time to mark out & drill a few holes :
With some prep work for nutserts :
Do note that the old mirrors had broken & were very hard to find replacements :
Will have to come back & make the center hole bigger as I didn't have a bit big enough ... :)
Any body remember the dust caps that go over ther screw heads ?
Onwards, Bantum ...
Post by El_Freddo » Wed Aug 26, 2026 7:45 pm
Looking good mate.
I’m going to have to go look to see if my mirrors have the little caps. I’m thinking they do as I haven’t noticed shiny screws holding my mirrors on - but then again they could be part of the furniture as such too…
Keep up the good effort! The wagon is looking amazing from the bits I’ve seen.
Post by Silverbullet » Sat Aug 29, 2026 9:34 pm
I went through the same thing with the mirrors, must have been 83' they changed to the chunky square type. My 81' wagon had the slimmer skinnier type until a careless bump from a wheely bin shattered the stem of one and sent it to the concrete. I don't remember having to drill the large center hole though :???: Nutserts are a good thing, usually :lol: If the screw gets cross-threaded and in the insert spins, it's a world of pain. Also worth doing if you haven't already, paint the bare metal edge before the nutsert goes in the hole. Even slather wet paint on it and crimp the nutsert into the wet paint, none of mine have rusted around the edge...yet...
Line away ...
Post by Bantum » Sat Sep 12, 2026 10:38 pm
Made some progress on the fuel system - with fuel sender unit cleaned up & new seal :
And panel beat the end of air box to fit :
Image :
Need some more fuel hose ...
Altnernate ...
Post by Bantum » Sat Sep 12, 2026 10:58 pm
Took apart the alternator & cleaned it up :
Replaced a plug :
Re-assembled :
Butt out ...
Post by Bantum » Sat Sep 12, 2026 11:28 pm
Took the seat out to fix a saggy butt :
Found the clip had come off :
Turned out to be a simple fix :
Happy with that ... :)
Subyroo
Post by Subyroo » Sun Sep 13, 2026 12:34 pm
Very cheap fix Bantum. :mrgreen:
Post by El_Freddo » Sun Sep 13, 2026 5:46 pm
Got to love an easy fix!
What’s with massaging the airbox to fit all about?
Not the stock alternator I’m guessing? Good effort giving it a birthday. Something I’ve not done. They just end up in pieces :mrgreen:
Fire in the hole ...
Post by Bantum » Sun Sep 20, 2026 2:40 am
The 'massaging' was done to make sure the intake doesn't cut the water pipe :
( as this car has a 50mm lift - the engine sits lower down, sat right on the pipe )
Think the alternator is a Bosch * Model number TBA - used to power extras ...
Managed to get it going ... but found I needed to replace a few dizzy items :
More to come ...
Cioa, Bantum ...
Post by El_Freddo » Sun Sep 20, 2026 9:11 am
That makes sense about the airbox snout mod.
With the new ignition module I’d recommend getting a new coil too. If the coil packs it in, it will kill the ignition module too.
Ask me how I know…
Return to “Bantum’s Works”
