90 model Brumby won't start
It has an EA81 engine in good nick & normally runs well. The other day it just wouldn't start, just nothing? The only clue I have is that when I went to turn off the ignition after trying to get it going it sounded like it alost fired when the key was halfway between ignition & off. Could it need a new ignition switch or key or whatever? Anyone got any clues?
Dasher
Dasher
Yeah does sound like the key barrel. My Ea81 barrel only fires when you hold it hard past the start section. Makes me scared every time thinking my battery is dead.
If you got no dash lights at all then it could be something more sinister.
Dave
Dave
Mine did exactly the same thing. Pull off the ignition plug and use a few bits of wire to hotwire it. Need to bridge the contacts for ignition on and the contacts for the starter. This will confirm if your barrel is faulty or not.
Alternatively turn the ignition on and assuming all the dash lights come on etc, go short your starter motor using a screwdriver and see if it starts.
F-ing wreckers charged me a fortune for a new barrel with keys. Thankfully it was just the back end that was stuffed, so I got one cheaper without keys and swapped the back parts around.
- Suby Wan Kenobi
try rotor button on dizzy
- Suby Wan Kenobi
Yeah check the dizzy. What year ea81?? Electronic or points distributer? If it's got points then it's most likely that.
Dave
Dave
