Brumby power windows
Jeff
Post by Jeff » Fri Feb 06, 2009 6:53 am
Hi , i have installed power windows in my brumby using touring wagon parts . They are very slow to go up , is this normal or do i have a problem?
Any suggestions
SUBIIE
Post by SUBIIE » Fri Feb 06, 2009 7:14 am
i did the same thing and got the same results.
they go down pretty quick though!
rtcb65
Post by rtcb65 » Fri Feb 06, 2009 9:14 am
Mine arent in a hurry either. Your just used to the newer stuff like the lib and wrx. lol. The M.Y. are like us. getting some age and slowing down. lol.
rtcb65
Redneck Rick.
Jeff
Post by Jeff » Fri Feb 06, 2009 12:45 pm
Very funny Rick. I thought it maybe an adjustment problem or is it time to see if impreza or lib window motors fit
Post by El_Freddo » Fri Feb 06, 2009 4:46 pm
Jeff wrote:Very funny Rick. I thought it maybe an adjustment problem or is it time to see if impreza or lib window motors fit
Hehehe... I got a laugh from it!
Sunnie's windows are slow on the driver's side and what I'd expect as the normal speed on the passenger's side. I'd love to know if the lib or impreza motors fit. The issue may not be the motor though, it could be worn tracks and guides from the driver having the windown wound up and down the most in the subi.
Post by steptoe » Fri Feb 06, 2009 9:21 pm
that was MY touring wagot electrics was it ? Would not expect L's to fit , but you just don't know. Is it a bad earth ? Silicone spray is always good for friction problems
Post by El_Freddo » Sat Feb 07, 2009 10:26 am
steptoe wrote:that was MY touring wagot electrics was it ?
Yep -> My brumby electric window install write up - Matt's brumby electric window install write up
They're pretty much the same, except I did my secondary arm guide a little differently... And if you use the Touring wagon electric window wiring loom + console and switches you'll retain the auto up and down funtion, its a good one to have ;)
stinky
Post by stinky » Sat Feb 07, 2009 8:09 pm
I've got them too and they're slow as well. The drivers side has trouble getting up and I have to help it most of the time. I was going to try replacing the motor, but trying to get the assembly out of the door is a real pain in the ass.
GTlegs
Post by GTlegs » Sun Feb 08, 2009 12:16 pm
I will find that its probably not the motor, but the electricity. Make sure the connections are good all around.
Outback bloke
Post by Outback bloke » Sun Feb 08, 2009 12:52 pm
That's right. It is the power supply/wiring. You lose a lot through the old wiring, switching/relays etc. Hook up a direct 12v to the up side and see how fast they go. You will be surprised. It is one thing I was going to do to the red ute but sold it before I got around to it.
Thalass
Post by Thalass » Sun Feb 08, 2009 2:27 pm
It wouldn't hurt to overhaul the motors, too. I don't know what kind of motor they are (but I would like to know as I'd be putting power windows in my brumby when I get it), but it shouldn't be too hard to overhaul - as long as you remember where all the bits go when you put them back together!
stinky
Post by stinky » Sun Feb 08, 2009 2:41 pm
Outback bloke wrote:That's right. It is the power supply/wiring. You lose a lot through the old wiring, switching/relays etc. Hook up a direct 12v to the up side and see how fast they go. You will be surprised. It is one thing I was going to do to the red ute but sold it before I got around to it.
haha it's the red ute I'm talking about :D
I'll have a go at doing that, shouldn't be too hard to work out the wiring for it.
Post by El_Freddo » Sun Feb 08, 2009 7:10 pm
Outback bloke wrote:Hook up a direct 12v to the up side and see how fast they go.
How do we go about doing this? Its something I'd like to do to Sunnie I reckon.
Return to “Trouble Shooting”
