Home made lift kit?
Home made lift kit?
Hi
I was talking to my teacher (who also has a brumby) and he said for about $50 for materials, I could make a lift kit at school. i was wondering if this was a good idea and how much it would cost to get the brake line and steering shaft extensions? Also what about insurance as I am a P plater?
thanks
thanks
- phillatdarwin
u can get brake lines made up for about $100 for rubber or s/s brade to adr for about $180 . as for the lift kit go for it and make one as if u know how to weld and drill holes procice it wood not be hard for u .
and if u look on hear u can find lots if u can not find it PM me and i will send u what i have found on the http://WWW.com
- TOONGA
there are these threads
showthread.php?t=14743
showthread.php?t=14590
which should give you an idea of what you need and how much work is involved
- Outback bloke
what kind of materials? that sounds too cheap!
- Outback bloke
- phillatdarwin
he means - Aluminum block.kona480 wrote:what do you mean the ally box?
What you'll be after is the steel box with crush tube welded inside the box. Crush tube is basically steel tubing that takes the load of the torqued bolts so the box steel won't crush in on itself.
With ally block its pretty easy to make a lift - just cut the block to the right length for each block and drill the holes required...
The trickiest bit will be the strut towers - you'll need to offset them an appropriate amount to fix the camber. Some one will know the correct offset to use - I planned on making my lift but it hasn't happened yet... Time will tell.
All the best with it, you'll love it once you fit it to your subi!
