Is an MY driveable without a rear diff?
Dane
Post by Dane » Thu May 27, 2010 4:58 pm
G'Day all,
I need to pull the diff out of my Brumby.
Is it fine to drive it in 2WD with the Diff, Driveshafts and Propshaft removed?
It won't be driveable with diff in at present.
Any help is greatly appreciated.
Thanks,
Dane
Post by Alex » Thu May 27, 2010 5:09 pm
yes, but your gearbox will spew oil everywhere.
Dane
Post by Dane » Thu May 27, 2010 5:18 pm
Ah crap. Thanks for the heads up!
I'd best find another diff then to keep me on the road.
Whilst tapping out a roll pin (and it was only a tap), the pin decided to seperate and the punch kept on going. It didn't feel any different to the other 3 I had just done or any others in the past. Until, bang, the punch and pin become one inside the stub axle. It's so stupid.
(It won't back out, I broke another punch trying)
Post by Alex » Thu May 27, 2010 5:33 pm
cover it in wd40 and try. Or else getting it nice and warm works too. I soemtimes use boiling water to heat it up or in a more extreme case try a blow torch or something.
Good thing wd40 isnt flammable!
Jeff
Post by Jeff » Thu May 27, 2010 5:35 pm
Dane keep trying you will eventually get it out
Dane
Post by Dane » Thu May 27, 2010 6:16 pm
Thanks for the encouragement :)
WD40 hasn't seemed to soak in well enough, but you have given me reason to buy a blowtorch :D
Post by Alex » Thu May 27, 2010 6:18 pm
btw if you havent already, drop the diff outta the car, can get abit more leverage that way.
Post by D3V1L » Thu May 27, 2010 7:36 pm
u cant drive without the rear shafts in...it holds the hubs together
Post by El_Freddo » Thu May 27, 2010 7:47 pm
D3V1L wrote:u cant drive without the rear shafts in...it holds the hubs together
This is an MY dave! You can run without the rear shafts in as the stub axles will remain in the hub...
You could try the coke can trick with a clamp to hold it on, this should help with sealing oil in the gearbox as you cruise around without the rear diff and prop shaft etc in. I've done it with my L series but its easier as the prop shaft is a two piece and is designed to leave the front part of the shaft in thus plugging the gearbox.
I used a grinder to get my pin out on one side. The shaft is still usable and held up well with the welded diff. Its still in the subi now. Basically you grind down the pin hole until you get to the stub axle, trying not to go too far in to start grinding the stub axle.
Post by D3V1L » Thu May 27, 2010 7:54 pm
wrong./..SORRY
LOL...i just realised i have WRX gear in my brumby....LOL.....sorry ignor my comment
mattl200
Post by mattl200 » Sat May 29, 2010 9:38 pm
find a front yoke from an old tailshaft plug the hole with it wire or cable tie it so it dose'nt fall out and drive but dont put it in 4wd
Dane
Post by Dane » Sun May 30, 2010 6:49 am
We fixed the problem. It took six hours of bastard hammer swinging. At one point, if you could take a core sample of the stub axle and inner, you would find the original punch, punch, drill bit, tapered punch, punch. The eventual fix...
A name brand punch and an even bigger hammer.
A big thank you goes out to Jan and Dave. It wouldn't have been possible without your help and persistance.
And thanks to everyone on the Forum who left some advice and encouragement.
See you on tracks :)
Post by AndrewT » Mon May 31, 2010 1:09 pm
Alex wrote: Good thing wd40 isnt flammable!
mine is...
I think there might be 2 different types. My can is pretty old.
Post by AndrewT » Mon May 31, 2010 1:10 pm
D3V1L wrote:wrong./..SORRY
your still running the original MY hubs etc tho? so your outer CV's etc should be the same as his?
Post by Alex » Mon May 31, 2010 2:15 pm
andrew im pretty sure its flammable only when its coming outta the can(ie the propellant)
once its been sprayed it isnt.
but then again....im pretty sure i remember trying to use wd40 as a flame thrower and it didnt work. So maybe the newer stuff isnt flammable.
Post by AndrewT » Mon May 31, 2010 3:12 pm
lol sounds like fun, I'll try it when I get home lol :)
*please note I may have trouble replying due to burnt fingers
Matt
Post by Matt » Mon May 31, 2010 5:55 pm
WD40 burns really Well!! :P And yes you can make a flame thrower! Don't try at home kids it throws a rather large flame!
"Claudia"
