Installed a Tridon hi-flow thermostat (TT-2041-180) from super cheap today $24. about 30% more flow.
Tweety has his main radiator the front now and 32mm S/steel tubes to hook it all up. I was hoping the extra flow would eliminate air pockets but not so. But it did flow better. This was evident when I carried out my ritual of cold start and high idle, wait for stat to open (shows a quick decline in water temp on the digital gauge). The temps fell quicker at this point- very noticable.
More relevant thread for VW owners with Subaru conversions.
Hi flow thermostat
- Tweety
Hi flow thermostat
- Tweety
Well if the hi-flow stats are similar to original stats in flow then thats good- the flow would be what the flow should be.
And the common Tridon I've been using is 30% less than the flow it should be.
So if I get you right Steptoe then hi-flow is proper flow quantity. Therefore, the flow in my cooling system has been less than what it should be. I went for a long ride today and the temperature is certainly more consistant and lower than what it has been, less prone to creeping up in traffic etc- very obvious it is.
So hi-flow stats should be renamed- normal stats. and the common stats- restrictive stats!!!
