Brumby pulls to the left
Mitchhsj
Post by Mitchhsj » Tue Jun 26, 2012 4:38 pm
Oh ok. Ummm how do ur lower control arm bushers look? Ur tiers are the same size / brand. I was a wheel aligner a bob Jane for a few yrs and with such a small light car the slights thing will fight it off the road. Bearings? Brake pads not rubbing ? Ur shock isn't shaged and stuck in a slightly lower possi? Sounds like one of those annoying ones mate. Keep at it
revmax
Post by revmax » Tue Jun 26, 2012 6:40 pm
Same size Mitch but not same brand. will fit others soon as i get it back from me auto sparky mate
revmax
Post by revmax » Wed Jun 27, 2012 9:25 pm
well the strut tops are opposite to what is pictured. But so are every Brumbys that I have looked at.
Swapped the front tyres over and it pulls to the right so there must be something up with the tyres.
Mitchhsj
Post by Mitchhsj » Wed Jun 27, 2012 9:35 pm
Good to hear it's an easy fix. The rims are the same. Slight different offset?
Post by steptoe » Thu Jun 28, 2012 8:48 am
a simple thing is always good and one of the last to be tried in many cases. Good stuff :)
revmax
Post by revmax » Thu Jun 28, 2012 4:01 pm
both rims are same maufacturer same size and same markings
EJ22Ute
Post by EJ22Ute » Thu Jun 28, 2012 7:50 pm
if the big hit which dented the rim? was bad enough maybe the radius rod mount has been moved?
revmax
Post by revmax » Thu Jun 28, 2012 8:06 pm
EJ22Ute wrote:if the big hit which dented the rim? was bad enough maybe the radius rod mount has been moved?
very possible
jakebrumby
Post by jakebrumby » Mon Oct 01, 2012 5:43 pm
sorry for the late reply but think i can shed some light here, tire pulls are very common in the industry, the wheel aligner should have checked that, check your tire pressures and make sure your tire has worn easily, the best way to fix the pull is make an adjustable\ camber/castor kit
revmax
Post by revmax » Mon Oct 01, 2012 6:48 pm
Thanks for the heads up Jake.
