Springs!
mithba
Springs!
Post by mithba » Thu Aug 16, 2012 10:04 pm
Hey guys, I've got an bug eye impreza with a 1 inch strut top lift kit and was wondering if I put king srping raising springs will that screw me geometry and subsequently my cv joints?
Is there any other springs I can put in it for a lift? such as forester springs?
Cheers fellas
Mitchhsj
Post by Mitchhsj » Thu Aug 16, 2012 10:50 pm
can you do a body lift in one of those??
Brumby Kid
Post by Brumby Kid » Thu Aug 16, 2012 10:59 pm
Hey,
I believe that a strut top lift is the same as raised springs.
Your altering the wheel end of the CV's and not the engine end.
So you have already screwed up your geometry.
I believe that you can get away with 2-3" before you have to really worry.
( others will confirm).
All this means is that you have to check your boots more often and they will have a shorter life.
If you want a lift that doesn't alter CV angles then a full body lift is required.
This lifts the body and the chassis off the running gear.
It involes strut top spacers AND other blocks between the engine, gearbox, etc.
Or bigger tyres.
Cheers Cam
Dads Car: 02 Impreza WRX STi
Mitchhsj
Post by Mitchhsj » Thu Aug 16, 2012 11:05 pm
well said... :)
taza
Post by taza » Fri Aug 17, 2012 12:26 am
The Impreza has the same suspension as the SF Forester (bug eye gen impreza). Yes could could put raised springs in but you could also just put Forester strut with standard hright springs in to raise it up. This would not hurt CV's as it would make it the same height as a stock Forester. You could then add springs springs or lift blocks ontop if you wanted, but with just the struts it would raise it up 50mm.
Taz
d_generate
Post by d_generate » Fri Aug 17, 2012 1:32 am
Not quite, the forester and Outback have lift blocks F&R between the X member and the sub frame which lowers the suspension and engine helping the CV's.
I can confirm the Bug and SF have the same springs so the Foz struts with some HD springs would be your best bet, extra camber bolts will be needed too.
mithba
Post by mithba » Fri Aug 17, 2012 1:08 pm
I already forked out 300 for the strut top. So I'm not to keen on swapping struts because they won't transfer. Im reallly just looking for a bit more ground clearance.
And where I take it off road I tend to bash the struts a bit so having a higher spring rate would be handy. Like ilk hit bumps and the spring fully compresses and I feel like the strut is going to smash through the bonnet.
thunder039
Post by thunder039 » Fri Aug 17, 2012 1:28 pm
the only way to get longer travel out of the struts is to use forester struts, otherwise you can use king springs and get them standard height. this will a firmer rate so it doesn't compress as easy. and if the struts are compressing that quickly i suggest slow down, wont be long to you have to replace a bent strut, i would know all ready been there ;)
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
mithba
Post by mithba » Fri Aug 17, 2012 2:07 pm
Yeah I know but its sort of a rally course me and my mates do time attacks on so slowing down isn't really an option. If I get raised springs, wouldn't that meant that they are firmer and "stretch" the strut further which gives it the lift?
thunder039
Post by thunder039 » Fri Aug 17, 2012 3:01 pm
im not sure if you can get raised springs for impreza's. even then there isnt must more travel is the shocks then whats stock this is the same on the forester
mithba
Post by mithba » Sat Aug 18, 2012 11:08 pm
Yeah they do make raised springs for imprezas. I realise in hindsight that forester struts and trailing arms would have been the better route but its too late now.
Cheers for the help guys
-Mitch
