im looking forward to finding outTOONGA wrote:
When I'm not looking after children or driving 240km in a round trip for work, I will find this mystery relay in my 89 brumby.
1. not unless you want to ...thunder039 wrote: 1. no need to rip up my floor vinal to check the relay unit?
2. there is no relays for the fuel pump?
3. therefore the only things it could be is a block, a stuffed pump or a fuse?
I'd remove the pump ( clean & inspect while your at it ) & do a 'bench' test with a suitable tank etc, to see if works correctly ...thunder039 wrote: ... so I went to strait to the fuel pump ...
... could the pump still be stuffed even though I can hear and feel it pumping ? ...
Correct - dosen't exist ...TOONGA wrote: ... So I have had time to look for this elusive box of tricks that doesn't exist ...
TOONGA wrote: ... anyone have any idea what those 2 relays do ? ...
Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ...TOONGA wrote: ... wait WTF thats not the flasher unit ... ZOMFG thats it the elusive fuel cut relay ...
ha haBantum wrote:Correct - dosen't exist ...
ah okBantum wrote: They are headlamp relays ... Items 29 + 30 ( going by wire colours )
That would be correct if the car was a 1982 -4 wagon or American delivered BratBantum wrote: Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ...
To make sure - Find out where the wires go + what colours they are ...TOONGA wrote: ... That would be correct if the car was a 1982 -4 wagon or American delivered Brat ...
phew lucky thensteptoe wrote:another phew as those cut out relays are about the 4 hunge mark or more exJapan.
Thunder - make sure you toss the crapped out pump so it don't end up as a maybe it was a good one in a few years time.....
