brumby clock in dash
Hi can anyone tell me if you can fix a clock thats stopped working in the dash of a brumby. Also i was thinking of maybe putting a tacho there instead but would like to fix the clock first.
- TOONGA
If you don't mind pulling your speedo console apart to repair the clock you may be able to get it to work again. I pulled a working clock out of my speedo and did this
see where the clock lived; it took about 2 hours all up, to get the speedo out, pull it apart, get the tacho to fit and put it all back together.
- TOONGA
It is 52 mm
http://www.ebay.com.au/itm/New-52mm-Car ... 3cc4c7655a
I removed the front bit of the tacho to make it fit, I didnt have to modify the cluster at all.
when I put it all back together it just sat in place.
Darn sight better result than mine when i tried to jamb in an L Series tacho over where the clock was. Many years ago I thought a clock in the dash of a car was seriously - a joke, ugly, waste of space. That was back when I wore a watch, and before I got a car with a clock - My Brumby !! Gonna miss that clock one day for sure ...52mm tacho eh ??
Gees I messed with that hard white plastic casing in the back of the cluster, was it with a die grinder ?
