Bantum's '85 Brumby ...
- 60766244
Mine doesn't have that button... Devo...
Sunnie the Brumby didn't have one until I changed the dash for a better one. Here's the original dash:
Also, if your heater controls light up someone's been playing as I believe the factory brumby setup has these lights disconnected due to the distractive reflection that occurs in the review mirror from the reflection of the controls on the rear window - something I noted after I swapped the dash over. If that's not the case dis-regard this info! But it makes sense to me...
All mine light up fully. A nice amber glow. I wouldn't say distracting, or reflective, I'd say warm.El_Freddo wrote: ...
Maybe they were rigged up by Mick when he did the conversion and was under there, or maybe it came like that. Not sure...
- Bantum
Head Unit ...
Mine didn't have any lights in them, until I swaped 'em over that is - works a charm ...
Another thought had crossed my mind - is that when the AC was installed, that demister could been added then ...
Here is another later shot of the dash with a proposed mockup of head unit ...
This is a far as I got though with updating the sound system ...
- 60766244
Looks awesome!Bantum wrote:Mine didn't have any lights in them, until I swaped 'em over that is - works a charm ...
Carpeting or Painting the board?
- Bantum
Trims ...
The back 'board' in last photo is only carboard - The aim is to do it in brushed aluminium, similar to what I've done with the Wagon ...60766244 wrote: ... Carpeting or Painting the board ? ...
The side's of Pod are to be covered in vinyl, simlar to door trims. As for the actual head unit, it may end up being a tablet PC of some kind - I haven't got round to that bit yet ...
I'm also looking to do a few pages on the Sound System outling the process, similar to how I did the LED's - When I get round to it ...
To much to do & not enough do$h ...
Ciao, Bantum ...
- 60766244
My mistake
Ahh, I assumed particle board or something...
Keen to see how it all turns out...
(On a sidenote, awesome work in the wiki)
mighty car mods put a i pad in an outback if you want to try and fit a i pad mini or i pod touch in there http://www.youtube.com/watch?v=u-ALYArl ... 4&index=20Bantum wrote:The back 'board' in last photo is only carboard - The aim is to do it in brushed aluminium, similar to what I've done with the Wagon ...
Ciao, Bantum ...
- Silverbullet
I'll be putting a tablet in my wagon when I get around to it; no problems with depth and you have your own sat-nav, internet, movies etc in car Only problem is I think you need an amp so you can run the audio out of the tablet into the car stereo. Looked at a few tablets and I think any 7-8 inch tablet will be right for Brumbies/MY's.
Do any of the tablets on the market come with the ability to plug a GPS aerial in?Silverbullet wrote:I'll be putting a tablet in my wagon when I get around to it; no problems with depth and you have your own sat-nav, internet, movies etc in car Only problem is I think you need an amp so you can run the audio out of the tablet into the car stereo. Looked at a few tablets and I think any 7-8 inch tablet will be right for Brumbies/MY's.
- Bantum
Yeah - I generally don't like anything with an 'i' in front of it ... ... ( Subaru's Excepted )
I've been looking at the Samsung Galaxy S2 with 4G or blue tooth ... I more like the Samsung Galaxy Note 10.1 updated with 4G and 'Jelly Bean' as an option ...
To get GPS working you may need a few add ons ...
Not decided yet ...
Not decided yet ...
- Bantum
Update :
I just did a quick measure check - the 'note 10.1' is way to big to fit at: 262 x 180 mm - Doh ...
The max size to fit space would be approx: 190 x 130 mm
The iPAD Mini comes in at: 200 x 135 mm - Hmmm, Close ...
I'll keep looking ...
The IdeaTab comes in at just 3mm over at 193mm and is way under the 130mm.
http://blog.laptopmag.com/lenovo-launch ... r-just-299
It's got an FM tuner and aerial but I'm not sure if it would be appropriate for a car install. More home work to be done but it might be worth a look.
And this Samsung is the same size as the Lenovo
https://www.samsung.com/in/galaxytab2/spec.html
- Bantum
DIN Mounts ...
Yeah I was also looking at that one, specifications Here ... price is Ok too - about $ 260 ...hydrowill wrote:Check out the ASUS nexus 7. Currently integrating one of these into my outback. Pretty cool piece of kit.
With dimensions of 198.5 x 120 x 10.45 mm it would need some creative mounting though - hight not a problem, width might be though ... bit tight towards bottom end of panel.
I was going for a standard double DIN (180 x 100 mm panel ) mount so that I can swap it out at any time for future upgrades etc ...
What sort of head unit ( for Amps - etc. ) would you need to run it in a car ?
P.S. - It does have a Mini USB + WIFI ... It could be linked via cable etc ...
- Silverbullet
I was looking at those too, until I found out they don't have and can never have an FM tuner That's all I use my stereo for at the moment!hydrowill wrote:Check out the ASUS nexus 7. Currently integrating one of these into my outback. Pretty cool piece of kit.
- Bantum
Sound off ...
Ok - for more sound system info head over to here :Bantum's Brumby Sound System ...
