3D Printed Replacement Parts ...
Moderator: Bantum
Horn Button ...
Post by Bantum » Sat May 29, 2021 3:22 pm
Ha - Could be ... :razz:
Was originally made for these but :
Cheers, Bantum ...
Re: 3D Printed Replacement Parts ...
Post by El_Freddo » Sat May 29, 2021 11:12 pm
Why are there captive screw three sections? That’s what I based my thoughts on!
Looks good, or is that the sample unit you based the design from?
Center Cap ...
Post by Bantum » Mon May 31, 2021 3:52 am
Yes, made a direct copy of the original :
Idea is to strip the metal parts & reuse them on the printed base where the old is past muster ... :/ ( broken or deteriorated )
You can download the file here : https://www.thingiverse.com/thing:1478397
Cheers, Bantum ...
Post by Silverbullet » Mon May 31, 2021 7:45 pm
Nice work Bantum, 3D printing has done so much good for the issue of old, brittle, non-existent (new) odd little plastic parts for cars and restorations.
I'm wondering, would you offer your 3D printing services for outside jobs? :razz:
The rear windscreen demister in my wagon doesn't work, I think the element is cactus. I've got an idea for a PTC heating element and a little blower fan mounted in the tailgate but would need some custom ducting/joiners to pipe the warm air to the base of the window. I'll do the design work, but I don't have a 3D printer, could I send the files your way?
Re: Printer Service ...
Post by Bantum » Tue Jun 01, 2021 3:58 pm
Yes had thoughts of doing something like that ( am in the process of build a 3D printer ) but not looking to go into business as there are too many regulation / tax implications for me, so it will be just a 'hobby' thing done in my spare time for now ... :/
Speaking of updates, just got this to put the printer in ... :)
Cheers, Bantum ...
Post by Silverbullet » Wed Jun 02, 2021 11:06 pm
Is that a fume hood? Good idea...
Understood, I might have to look into getting myself a 3d printer at last! ;) Have thought about it a few times but could never justify getting one.
Printer Enclosure ...
Post by Bantum » Thu Jun 03, 2021 1:33 am
Yep it has several functions, helps to keep the heat in and stable & stops the fumes spreading ... ;)
( the fabric is supposedly fire retardant - yet to test it, may still need to add a filter somewhere )
Printers have come down in price too, got this for under $400 ( spent more on peripheries but )
If was doing mass produced stuff, I'd go for a more industrial type ... ;)
( they will cost more mind you )
Cheers, Bantum ...
Door Pulls ...
Post by Bantum » Thu Sep 02, 2021 4:25 am
Did a test print on the Door pull :
Still more work to do ... :/
Post by TOONGA » Thu Sep 02, 2021 11:25 am
nice it looks like the 41 year old sun damaged ones on my sedan ;)
Good to see you experimenting though keep it up.
Dust cover & End Cap ...
Post by Bantum » Sun Sep 19, 2021 5:21 pm
Did some more 3D stuff:
Roof Rack End Caps :
Door Dust Cap :
Might want to print them in flexible material ... ;)
Cheers, Bantum ...
Door Pull Trim ....
Post by Bantum » Sat Dec 25, 2021 4:08 am
Well it's been released :
https://www.thingiverse.com/thing:5161635
See what you make of it ... :biggrin:
Cheers, Bantum ...
Printer upgrades ...
Post by Bantum » Sun Jan 30, 2022 4:08 am
Well this lot finally arrived :
& opened :
Unpacked :
& the Duck :
Just got to work out how to install it now ... :/
Ciao, Bantum ...
Post by Silverbullet » Fri Apr 08, 2022 9:32 pm
That's a nice little lot there Bantum 8-) is that upgrades for your printer or an entirely new printer? Almost looks like stereo-lithography kind of printing gear...
Re: 3D Printer Parts ...
Post by Bantum » Sat Apr 09, 2022 2:37 pm
Thanks, haven't got round to installing all of it yet.
BQ hot end is lighter & supposedly can handle higher temperatures ... to be mounted on one of the tool plates.
The Hermit Crab ( & tool plates ) is so I can interchange printer head with other devices like laser / cutter parts.
Idea is so I can do engraving & cutting stuff on same machine.
Have also been upgrading the power /control boards :
Whether it works or not tis yet to be determined ... :/
Ciao, Bantum ...
Let there be light ...
Post by Bantum » Sun Feb 12, 2023 4:10 am
Well I need to be able to see things better - so got me something to light up the print bed : * Edit - link broke ... :oops:
testing :
And few more bits added to the parts bin :
Got to get back to finishing the printer now ...
Ciao, Bantum ...
Door Pull Test Print ...
Post by Bantum » Sun Feb 12, 2023 4:18 am
Well I did a thing & got this :
& back side :
Will have to do some more tweaking to correct some of the errors found - bit thin in some places + clips didn't print correctly ... :/
Welcome feed back from others who have got round to printing it ... :)
Cheers, Bantum ...
Post by El_Freddo » Sun Feb 12, 2023 8:43 am
That looks quite good in the pics Bantum!
How will that material fare in the cabin of a sun soaked vehicle, would it be likely to warp?
Keep up the good effort!
Print longevity ...
Post by Bantum » Sat Jun 17, 2023 4:14 am
Depends on what its printed with - ABS, same as original - PETG, yet to be tested, but should hold up just as good if not better.
Will have to leave a sample out in the sun for a couple of years to check on suitability.
Cheers, Bantum ...
Return to “Bantum’s Works”
