Bang Bang Bang
KERAZY
Bang Bang Bang
Post by KERAZY » Thu Nov 02, 2006 5:26 pm
yep. driving the other night, just crawling around nicely. gave it a little stick before a corner, started slowing down, back down to second, decelled til about 20, started going again round the corner, wasn't exactly full-on quick, normal accell speed. get up to 50 in 3rd, then start backing off for a corner, and 'BANG'. im thinkin wtf.. i give it a tiny bit on a straight after a corner, then let the accel off again, then BANG, then i stopped the car. im thinkin 'CVs, i know it'. I turned out to be right. stuck it in first and slowly let the clutch out, left CV was spinning, the car wasn't moving anywhere. i havent had a good look at it, but i reckon ive snapped a joint.
righto, so now what? im dismantling it in a week, is there anything i should know before i do it? what do i need? where do you get the cones to slide the boots on?
BrennyV
Post by BrennyV » Thu Nov 02, 2006 5:36 pm
Wack her into 4wd and have some RWD fun :D THEN
All you need is a good punch set to get the pins out from the shafts! Bout it. Very easy process ;)
ohh and be sure not to over tighten your castle nut...
Hunter S. Thompson
Matt
Post by Matt » Thu Nov 02, 2006 5:54 pm
Also a CV tool comes in handy for the straps if you are replacing just that CV.
"Claudia"
mattims
Post by mattims » Thu Nov 02, 2006 10:01 pm
you can over tighten the castle nut? is that the big one on the outside. I thought it was done up as tight as could possibly be done.
Post by D3V1L » Thu Nov 02, 2006 10:14 pm
but when ur andrewt, u manage to strip the thread on those castle nuts....
dave
coupe
Post by coupe » Thu Nov 02, 2006 10:45 pm
You need to tighten them up to 150 foot/pounds.
Use The Fork Luke
mattims
Post by mattims » Fri Nov 03, 2006 9:23 am
that all, well mine are way over that. Will it cause any damage to the bearings?
Post by AndrewT » Fri Nov 03, 2006 10:03 am
Yes I actually managed to completely destroy the thread on the outer CV where the castellated nut goes. I've always been told by various people to just "do them as tight as possible" but I guess I don't know my own strength :p
Now they are done up slightly less than as tight as possible.
Post by steptoe » Fri Nov 03, 2006 10:10 am
broke shaft....sh1t how then do you undo nut with no gearbox to help hold it ... just the brakes ??
KERAZY
Post by KERAZY » Fri Nov 03, 2006 9:01 pm
yeh when we did the boots, we just stuck the handbrake on and held the brakes. completely different thing i spose, but it was in neutral when we did the boots. silly me.
who wants to sell me some boots and a CV?
im unaware of this 'CV Tool's existance, and i dont have a torque wrench, we go to the point where it requires a hammer to tighten it (hitting the spanner - big freaking spanner)
KERAZY
Post by KERAZY » Sun Nov 05, 2006 5:00 pm
thank jesus with a stick. it wasnt the CV.
i dont know how i didnt think of it. it was the hub! splines had worn away. the banging was it slipping when it wasnt as worn down. i shoulda thought of it sooner.
now i know why when you drop the clutch, it bangs. silly me.
i had an extra hub connected to solid discs in the shed. changed the discs over, used the other hub, its all good now.
Post by D3V1L » Sun Nov 05, 2006 5:34 pm
good to hear u solved the problem mate
dave
Post by El_Freddo » Mon Nov 06, 2006 5:03 pm
I have also had klunking/banging noises up front and presumed the cv's were on the way out...
Turned out that my castle nuts weren't real tight, the right hand one started squeeking as the wheel turned when i was out four wheel driving on saturday, after i got out to find out what it might possibly be and found the castle nut finger tight (still with pin in). Done it up and did the left one last night.
Could i have a bearing collapsing on me to make a castle nut finger tight?
Sorry if i've hijacked your thread.
KERAZY
Post by KERAZY » Mon Nov 06, 2006 6:22 pm
nah its cool. funnily enough, my castle nut was loose also. do you think it could be related?
