Engine cooling, or the lack of it.
- tobyduffill
I have a 86 model LEONE that is getting warm. It has just had a new thermostat and has had the radiator flushed with plenty of water flow. Still can not find the problem why it is running warm, 4mm from top of guage. No bubbles in the radiator. Is an automatic radiator larger than a manual or can a three or four core be built, any ideas welcome. Toby
"SUPERSUBIE"
1986 FWD LEONE, 2 1/4" Exhaust, 13" x 5" SUNRAYSIA Wheels, KINGS Springs
UNIDEN Scanner for listening to the Emergency Services and a GARMIN GPS
WEBER 32/36 Carb coming soon... Still coming damn the $$$
"I HAVE TRIED, BUT IT WILL NOT DIE"
Yeah definitely check water pump.
The car should run perfectly well on the standard single core radiator so best to find the root of the problem before getting a custom larger radiator.
EZ30 L series - Monsterwagon
