please help!! clutch/gearbox related
i sourced a new clutch for my liberty and i have just spent ALL day trying to get the gearbox off the motor ive managed to get it off 10mm but it wont budge anymore and its starting to really really frustrate me, i cant get it off anymore and i cant get it back on!! please help, any suggestions or ideas or is there a trick to getting this box off?? i need this car to get to work so its an urgent issue car is a 1990 rs turbo driveline dave
I have nothing that may help... all i can say is i had a similar problem with an EA81 motor... thrust bearing was seized on... Tied the car to a tree... and the gear box to the hatch... and still wouldn't come out... Ended up having to remove the motor with it.... winched the box up with a hoist and belted the engine off the a malet... i wouldn't do it this way if u want to keep the motor though.
Jeff
ooooh this is news to me....ill go try now..cheers dude
- tim_81coupe
AHAHAAHHAHAHAHAHAHAHA
Sorry, had to laugh. Happened to me too when I first attempted a clutch change.
The pin holds the clutch fork, the clutch fork holds the thrust bearing, the thrust bearing holds the pressure plate which is bolted to the motor.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
yeh....*slapps self* its slightly diffrent to an L box after ****ing around all day i did the change in 45 mins after jeff's tip:P...i feel a little stupid now..ahahaha dave
This little bit of info is also the one that caused all the trouble with a certain MY99 gearbox removal....you remember....the one with all the sparks and stuff
Got me aswell years ago first time I'd ever worked on an EJ (also an MY99 wrx).
EZ30 L series - Monsterwagon
- Outback bloke
bahahah yeh, least ya didnt mangle ya presh plate! i managed to rip my gc8 box out without poping out the thrust bearing !!!! nuthing a long flathead wont fixAndrewT wrote:This little bit of info is also the one that caused all the trouble with a certain MY99 gearbox removal....you remember....the one with all the sparks and stuff
Hunter S. Thompson
Hunter S. Thompson
