3inch questions
rigby
3inch questions
Post by rigby » Mon May 21, 2007 8:22 pm
when installing a 3 inch lift kit do u need to replace any parts like springs and struts ?, plus dose anything else neede to be changed cheers?
Post by AndrewT » Mon May 21, 2007 8:24 pm
nah. if your just upgrading from 2inch you should be right.
rigby
Post by rigby » Mon May 21, 2007 8:31 pm
ok sweet no need to extend brake cables and stuff
Post by AndrewT » Mon May 21, 2007 8:40 pm
Nah they all work fine - I don't think they even needed to be changed on Lapsed's wagon which has a 4" kit (somebody correct me on that if im wrong tho)
SuBaRiNo
Post by SuBaRiNo » Mon May 21, 2007 8:40 pm
3 is fine with brakes and cables... maybe need to trim a little more off ya radiator hoses but unlikely.
Your exhaust will sit 1 inch lower too... a lot of people get there exhausts modifed so they are up nice and high when they are happy with the size of there lift.
Dave
rigby
Post by rigby » Mon May 21, 2007 8:48 pm
ok cheers good help and when is there another wa trip i need to get out there
90brumby
Post by 90brumby » Mon May 21, 2007 11:17 pm
yer my 4 inch lift caused my zorst to sit very low (as some peolpe saw)
also the top n bottom radiator hoses need adjustin the gear stick sat quite low n thats bout it
tristan
Ps bolt ur 3 and 2 inch together n make a 5 inch that would be cool but very very weak
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by D3V1L » Mon May 21, 2007 11:23 pm
rigby your car is fine...although we did have big issues with your 4x4 linkages...hmmm...but everything should be fine...bar the exhaust may need some attention
90brumby
Post by 90brumby » Tue May 22, 2007 1:13 am
oh n yer i cant select reverse in low range and is hard to select in fwd
but i think that is all
SuBaRiNo
Post by SuBaRiNo » Tue May 22, 2007 9:33 pm
I will bet my last remaining nut that your reverse problem is just a sloppy linkage.
Dave
Post by Subafury » Tue May 22, 2007 11:01 pm
hahah subarino is a monoball
Post by Alex » Tue May 22, 2007 11:07 pm
LOL...
yeh Rigby, nothing major, didnt we all tell you to go with a 3inch from the beginning!?
rigby
Post by rigby » Wed May 23, 2007 12:00 am
yeh you may of but now i have relized and alex i want to use your wheel carrier to make mine
Post by D3V1L » Wed May 23, 2007 8:59 am
u want to use his wheel carrier??? his aint comming off in a hurry :D
rigby
Post by rigby » Wed May 23, 2007 10:09 pm
when i say use it use the same design to make mine they sound like very good welds dave
Post by Alex » Wed May 23, 2007 11:14 pm
do u want me to take some detailed photos? or do u want to see it in person?
BlackMale
Post by BlackMale » Thu May 24, 2007 10:15 am
Sorry about the delay buddy... flat out ATM will get to you.
