Pix Of A Vlsd And Plated Lsd
chriSTIan
Post by chriSTIan » Fri Nov 23, 2007 9:02 pm
Hi all
Has anyone got pix of the above rear diffs?
I bought a rear diff that's supposed to be a plated diff,but i am not sure what i should be looking for in there.
I've removed the rear plate .
Also what does a vlsd look like with rear cover removed?
Thanx
Chris
Jack
Post by Jack » Fri Nov 23, 2007 9:26 pm
Don't have any pics for you but I found this link via google
http://www.rallispec.com/prod_diff.htm
1999 Outback (some mods)
1989 Brumby (more mods)
Subaru - Symmetrical All-Wheel Drive
Ben
Post by Ben » Sat Nov 24, 2007 9:32 am
AWWWWW YEAHHHHHHHH
RST-1903 Subaru Helical Front LSD Kit $1050
Recommended for street & track use. This torque biasing limited slip differential provides smooth, consistent, and quiet operation. Sealed maintenance free operation with no special lubrication requirements. Improves traction at the front wheels allowing the driver to get on the power as early as possible out of a corner. Kit includes LSD and stub axle set making it a direct swap for all Subaru 5-speed gearboxes.
Please watch before posting!
chriSTIan
Post by chriSTIan » Sat Nov 24, 2007 10:40 am
Nice site,want to see pix of factory diffs.
brumbyrunner
Post by brumbyrunner » Sat Nov 24, 2007 7:54 pm
might be an idea to post a pic of yours so that we can tell you what it is.
Settlement Creek Racing
Post by AlpineRaven » Sat Nov 24, 2007 8:24 pm
This LSD is Viscous LSD from RS Liberty -
Post by AlpineRaven » Sat Nov 24, 2007 8:26 pm
Another one I found here in my photo album -
Left side is open diff and right is another VLSD i had (had 2 of them that time)
chriSTIan
Post by chriSTIan » Sun Nov 25, 2007 9:46 am
Hi,thanx 4 the pix,has the left one been cut open or do they come like that?
What is it off? The vlsd,where is the viscous coupling?near the crown wheel?
Is the housing(round part) bigger in the vlsd than in the open.
Will post a pic of mine soon
Ben
Post by Ben » Sun Nov 25, 2007 10:46 am
One on the left is a standard open diff, that is what they look like when you crack the rear cover.
Post by D3V1L » Sun Nov 25, 2007 7:14 pm
a plated clutch has a very distinctive 2 plates inbetween them..unlike the vlsd where it looks enclosed (as it is for the oil) the plate lsd has very visible clutch plates in it that sit in the middle
dave
chriSTIan
Post by chriSTIan » Sun Nov 25, 2007 8:59 pm
Here's a couple of pix of my "plated lsd"
What do you guys think?
Post by D3V1L » Sun Nov 25, 2007 9:45 pm
that looks like a clutch pack to me but i cant see inside
vhte viscuc LSD tend to have a completely sealed section inside the housing..this is where the high viscosity oil is housed between the plates
dave
Post by AndrewT » Sun Nov 25, 2007 9:57 pm
That looks just like the insides of my one (clutch pack from an RX turbo Leone).
I havn't seen the inside of a VLSD one before.
Post by AlpineRaven » Mon Nov 26, 2007 5:28 am
It looks like VLSD, but could be clutch pack LSD as I havent seen/opened up CLSD.
Another thing to ask - pull out the RHS drive shaft, it will be hard but will pop out, what does the end look like?
Do you know any history of it ie. where and which car is it off from?
Post by AlpineRaven » Mon Nov 26, 2007 5:29 am
Oh another thing - I'm against to open the LSD centre up because once you do it wont be the same again. Get the pros do it.
chriSTIan
Post by chriSTIan » Mon Nov 26, 2007 7:28 am
its got late model wrx "male" cv's on it,so its the long one on the drives side.
Still confused ,it looks a lot like the vlsd in the earlier pix
Suby Wan Kenobi
Post by Suby Wan Kenobi » Mon Nov 26, 2007 11:08 pm
The pic you have ChriSTIan is of the VLSD.
The long road ahead
PeeJay
Post by PeeJay » Wed Nov 28, 2007 8:43 pm
AlpineRaven wrote: Image
Wouldn't this be an open diff because it still has spider gears? I've got one exactly the same here and when I rotate one side the opposite side rotates in the opposite direction.
PeeJay
Post by PeeJay » Wed Nov 28, 2007 9:12 pm
But it can't be an LSD, you can see the gears through the hole, identical to mine. Unless there is something I'm missing? Mine was supposed to be a VLSD as well.
Post by D3V1L » Wed Nov 28, 2007 9:45 pm
a viscus LSD has no visible spider gears
the viscus coupling is several plates inside a sealed area that has a very high viscosity oil. hence the nam VLSD
a clutch pack still has a couple of gears visible in the centre but has different forms and different ways in which the clutch plates work..come hav eplain simple clutch plates in place of the spider gears, but most have several gears there which are joined by a clutch system to even out the load and provede the limited effect....ill try find the photos of mine somewhere caus i have had both viscus and clutch pack...IE: my current wrx diff is a clutch pack that i have had repacked and its highly visible clutch packs in there as well as gears(sspider gears) in the centre...and my liberty had a VLSD...which had a closed of secion for the oil and plates
dave
