loud clicks from wheels after parking
liberty99GX
Post by liberty99GX » Fri Jan 25, 2008 7:28 am
Hi there,
after having my Liberty parked (handbrake and auto in P), when maneuvering out of the driveway, the first couple of times I apply the brakes, even when softly, there's loud clicks, usually from the front wheels and sometimes from the rear ones. After that, i.e. in normal traffic braking, no more.
CVs? I thought if they were gone they'd be audible when turning tight corners before anything else, but I don't have a problem there.
Any suggestions as to what it is?
Thanks,
Matt
SUBYDAZZ
Post by SUBYDAZZ » Fri Jan 25, 2008 12:14 pm
Does it do it when going in a straight line or only when turning? What happens if you park somewhere else?
SUBYDAZZ
Post by AndrewT » Fri Jan 25, 2008 2:17 pm
Sounds like maybe the brake pads might be loose, their locating springs might not be working properly. When you have the handbrake on with the car in a position to roll backwards perhaps the pads get shoved to one side then when you apply the brakes to slow down when driving forwards they get slammed the other way (hence the noise).
You could test this out by reversing slowly down the road then applying the brake, it probably will make the click then too.
I'd take the wheels off and have a good look in there to see if theres anything out of the ordinary.
GTlegs
Post by GTlegs » Fri Jan 25, 2008 2:47 pm
Clicks from wheel areas (when you drive on smooth roads) could generally be happening due to a number of reasons.
1) CV joints (click quite loudly, but generally only when you turn)
2) Bearings (generally only click if dirt got in or not packed well), but the sound is fairly quiet, and happens when the wheels move. You can test this by jacking up the car and turning the wheel by hand.
3) Worn out front suspension bushes - but generally only when you go over bumps
4) Worn out shocks can radiate knocking sounds into the wheel area.
dwayneb
Post by dwayneb » Fri Jan 25, 2008 4:10 pm
But how about the Hub nut done up tight?
Matatak
Post by Matatak » Fri Jan 25, 2008 6:59 pm
check bushes.
expecially radius rod bushes as they are basically what stop the wheel fm jumping backwards as the brakes are applied.
if theyre worn the wheel has excess travel when ur accelarating and braking.
ie. a front to rear motion in the wheelarch
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
vincentvega
Post by vincentvega » Fri Jan 25, 2008 8:19 pm
radius rod bushes?? its a liberty - it doesnt have any
Busdriver
Post by Busdriver » Fri Jan 25, 2008 8:32 pm
I'm with Andrew T on this one, seen what hes talking about happen a few times before, and sometimes when the clips on the ends of the pads weaken and the pads move back and forward when changing direction from reverse to forward the ends of the brake pads backing plates wear or "mushroom".
this can be fixed with a small hammer,just sit the pad on a vice or something and peen the ends of the backing plates back over so it is a tight fit in the caliper or mounting bracket again. Dont bother if the pads are worn out though, just put new ones in and this noise should be gone.
Suby Newbie
liberty99GX
Post by liberty99GX » Thu Jan 31, 2008 7:40 am
thanks everybody for the quick replies and suggestions.
had to put new pads on and it looks it was what Andrew T and Busdriver thought it was.
cheers,
Matt
Return to “Trouble Shooting”
