wanky wagon new motor ideas?
hi alex,
im just finishing off my turbo conversion now and i can tell u its frickin scary as driving it with shagged suspension and no wheel alignment haha. But well worth it, id say go turbo conversion just so u can laugh at VL turbos when u beat them.
Adam
Adam
L Series current mods:
EJ20G, 3" lift, Roo bar, spotties, EJ Sporty steering rack, desert rats, 27" tyres, 2.5" exhaust
The EA's don't have to stripped down to get the rods out - just the heads off, I'm guessing that the EJ would be no different... But i reckon if he's going to that extent you might as well split the block and stick some new bearings on the crank too.D3V1L wrote:hahah matty boy u dont understand how different boxer motors are
to get the rods out the motor has to be stripped of nearly every nut and bolt AND the block needs to be split into its 2 halves....
a big task at hand but not undoable
i think a rebuild is a better idea as well
Obviously a replacement EJ22 would be the quickest, but...
Just turbo the bitch!
Bennie.
EJ22 is pretty bullet proof, can take a fair hiding, but the EJ20G will just give the rest of you car a hiding and be forever fixing stuff.
wrong..... have to split the block with ej motors. very different to ea motors
trust me ive just done one and have the manuals for all the motors
dave
dave
El_Freddo wrote:The EA's don't have to stripped down to get the rods out - just the heads off, I'm guessing that the EJ would be no different... But i reckon if he's going to that extent you might as well split the block and stick some new bearings on the crank too.
Bennie.
I don't rekon the EJ25 is enough of an upgrade to justify the swap. Maybe if you can get one for the same or similar price as an EJ22.
The EJ20turbo will be a very easy upgrade. It will run off the same wiring loom with a few minor additions for the boost solenoids. You would need to upgrade the clutch and either modify the engine crossmember or get a turbo one.
EJ20turbo will blow you away but if you stick with the EA driveline be prepared for significantly more breakages then you already get!
It's worth noting that my wagon hasn't suffered any breakages at all that can be directly attributed to having an EJ20turbo - without even running an engine stayrod. Perhaps it is driving style, not too sure, you all know I don't really hold back. I can't imagine the Outback gearbox I'm using is a huge amount stronger than an L series one but running in front wheel drive on an L series box does take it's toll on the gearbox itself and the chassis of the car due to the twist from the extra torque.
EZ30 L series - Monsterwagon
I'd just get a low k import EJ22. Throw it in and drive..
fyi I have found EJ22's are quite rare at import yards and usually very expensive. Much better off sourcing one from a locally smashed or wrecked car.
if u go for a new EJ22.
then u may need another Series 1 engine as the Wiring Loom on a Series 2 is a bit different.
it can probly be worked aorund quite easy but u better find out first.
Subarino shuld no.
also a series 2 engine is a better one
Subarino shuld no.
Wagon is no longer....
5 minute job to swap over the little harness that runs under the inlet manifold pretty much to change between S1 and S2 I believe.
Whats the difference between series 1 and 2?Matatak wrote:if u go for a new EJ22.
Subarino shuld no.
showthread.php?t=9300
thats bout all i no.
and theres a few more with the Gen1 and 2's that ive seen
let him get a turbo! u know how bad he wants a bov
Hunter S. Thompson
Hunter S. Thompson
