EJ22 Thermostat
EJ22 Thermostat
What way should the thermostat sit in an ej22? Thinking it might be back to front.
- Outback bloke
TW83 wrote:Thanks for that, it was in correctly.
Does anyone know the temperature range EJs should run at?
Im between 88 and 93 Celcius at idle with one fan running. I thought this is too high because the thermostat is rated at 77 C.
it may be rated to 77C but it only starts to open then. below 100C running temp is fine neways.
Is the fan you have hooked up controled by the ECU?
Dave
Dave
no it wont be fully open at 77Subafury wrote:mine sits right on 90. and alex is right it will be fully open at 77c
my guage shows me aorun 85 normal driving obviously increasin a bit when offroad
Wagon is no longer....
