1.8 turbo? is it legal in Nsw? 2" lifts are they legal?
I have just bought a L series with 1.8 Turbo and 2" lift and want to know if they are legal in NSW? I know I need some flares for the tyres I have, 14" 195R.
Guest
Please stop yelling at us all (turn CapsLock off).
Engine is Legal - so long as your insurance company knows about it. It must be complied.
Lift kit is also legal - so long as your insurance company knows about it. 50mm lifts are an Owner-Certified modification in NSW.
For more information on what is roadworthy/what is not, refer to VSI06, accessable from this link.
Guest
It still must be complied (the engine that is), ie you'll need a blue-slip. To check if it's complied, verify the engine number against the rego papers.
Have you got rear discs?
An Engineer's Report, for less than $500, is the best insurance against defect notices you can buy.
195R14s should still be just inside the guards on and L-series with Sunrasia wheels. Maybe you could get the guards flared instead.
So if I put a turbo motor in my wagon, and i have rear discs. what will i have to do before i drive it on the road?
Guest
Guest
If you don't draw attention to yourself, or don't hang out with street hoons etc, or drive like a hoon, you have little to worry about. As said before make sure your car with correct engine No is registered. ie blue-slip.
not all rego check places do the blue-slip, and maybe they may want an
engineers report these days, (or maybe not, depends on where you go)
