how many revs you do at 100 kph? IN TOP
Gen 2 Liberty 5spd AWD D/R box 3.7diff, 2850 rpm @100kmh, 195/60/15".
What revs would I be getting if I get these tyres - 205/70/15"?
FINALLY !!
I put my spare L series tacho to good use today.
I hooked up a cig lighter power cable to the contacts at the back of the tacho and the tach wire to the yellow coil wire of me Brumby EA81 Lseries 5 speed, 3.7 diff with 195/50-15's
Happy to say that it sits on 3000 at 100true km/h - that's is 20% better than top in the turbo 3 speed GLTA which is 3000 at 80 !
I can do roundabouts in fourth at 1000rpm and still pull away (slowly) without shudder - that's LPG for you (and gettin' lazy with the auto above and crunchy > to 3rd!!)
EJ22 LEONE SEDAN running EA FTAWD with 3.7 diffs rolling on ruffly 26" 14's gets 100KMH @ 3000rpm
Hunter S. Thompson
Hunter S. Thompson
EA82T Powered 'L' series Wagon with Custom 4.111 AWD Gearbox with 3.9 Liberty internals on 27" Nankangs -> 3100Rpm @ 100kms on GPS.
http://www.subiparts.com.au
0438 887 746
0438 887 746
Justin, what's the actual difference between gps and speedo using 4.111 ratios in a Liberty box plus Nankangs? I'm going to be getting the Brumby converted to EJ22 / AWD / 4.111 / Nankangs soon and am curious as to how accurate the speedo will be with this combo.Xtreme_RX wrote:EA82T Powered 'L' series Wagon with Custom 4.111 AWD Gearbox with 3.9 Liberty internals on 27" Nankangs -> 3100Rpm @ 100kms on GPS.
Also, do you have any rear diff hanger nolathane bushes (Brumby) for sale? My OEM ones are buggered.
1999 Outback (some mods)
1989 Brumby (more mods)
About 8 - 10Kms/Hr out.... Ie speedo says 90ish I am doing 100Kms/Hr
0438 887 746
0438 887 746
- Thalass
My 99 Outback sits at around 2600rpm in 5th gear at 100km/h. I'm not 100% sure of the exact figure - I forget, but it ought to be around there. The gearbox is from a later model Forrester, though. It's supposed to be the same as the original outback gearbox.
I was scratching my head recently about my fuel consumption, thinking that perhaps the gear ratios were slightly different so I was using more fuel at the same speed and all that. Then I realised it's been hovering around 40 degrees here lately and the aircon has been blasting away full time!
2nd Gen Liberty, 3.7 diff, 2550 RPM at 100kmh 205/70 15" fuel consumption increased since new larger tyres fitted. (been getting 600kms before light comes on)
Old tyres same as above posting was 195/65 15" used to get around 500kms when light comes on.
Speedo is corrected by JayCar Speedo Corrector fitted by using GPS.
