Fascia Kits for stereos
I have a brumby and want to neatly put a stereo in the front. We have customly made a fascia kit for now but want to know if there are ones made for the car. I have searched the net and found some for a subaru "brat" but it doesn't look like it would fit. Has anyone else had this problem?
I think i know the facia kit your refering to. You may require some custom panel building to make it suit properly... an easier option may be to purchase a different MY wagon or Brumby console that it may fit better.
Dave
Dave
- tim_81coupe
- WombatRacing
I have the same problem I have a new CD player to go into my 89 Brumby but dont want to go cutting up the consle or any thing. Will fitting the 83/84 wagon console allow me to fit this and will the console leave room for the gear shift? I dont want to be bashing my hand on it every time I change gears.
Cheers Troy
Cheers Troy
Ah the old "only change CD in 2nd and 4th gear trick'
Heat up your gear shifter with an Oxy set and bend the basterd back a bit.
5 speed conversions and lift kits seem to make the shifter sit forward.
Cut'nshut it or bend it.
1989 Subaru WonderBrumby II
- tim_81coupe
- tim_81coupe
- BaronVonChickenPants
For the benefit of those who don't have a tourer in the garage:
And as far as the 45 degree angle, I'm sure you've played around with a spinning bicycle wheel tilting it and so forth, anything that spins suffers this gyroscopic force, including...you guessed it, cd's.
If you did mount it like this it wouldn't be long before either a cd or the head unit itself exploded.
Jordan.
Jordan.
- tim_81coupe
- tim_81coupe
- vincentvega
- vincentvega
I just encounted the very same problem, will modify a new blank facia to compensate for the angle by adding corner pieces between.
CD/Tuner unit length with heatsink on back makes a tight fit. I have that consul too, but will lose the ashtray etc to suit. The CB was in there before too, but will have to go elsewhere for now, unless I can get a slim unit.
