nice lookn brumby mate! those 27's set her off90brumby wrote:yep only had to slightly trim the front garuds but the rear required no mods at all
hers a few pics
the pic (its also upside down this is the pic im talkin about) with the spring is the lift on the front im not sure wat others cars have this but yer its the only lift mines got
Perth roll call.
Hunter S. Thompson
Hunter S. Thompson
i am unsure for the MY's however they are standard fitment for the L.90brumby wrote:r these struts not standard if not do u no wat they r
Note to all interested parties though even though they are adjustable when these are fully would out/up they may be the same lenght as your standard non-adjustable strut (obviously depending on what front strut your running now). Therefore i would suggest that before you run out and get some pull out the tape measure and check.
LOL... wrong... they are standard for MYs and Brumbys... a similar set up was found on i belive the 85 L series but not the same and not on every L series year. Yes they are wound all the way up... but no that is not the same height as the aftermarket non-adjustable struts for the brumby/MY's.
It is best to keep the struts wound all the way down to extend the life of CV joints and boots... it also helps with the camber unless something else has been done.
I wonder if anything is different up near the top of your struts.
Dave
Dave
i had them struts in my old L series....
dude... make a new post in the WA section asking that.
Dave
Dave
