lseries bits
lseries bits
am converting my brumby, chasing some bits: front l series driveshafts, stuffed is fine, front sway bar and couple window winders if they fit brumby. can get rid of my/brumby roo bar with brackets alloy tube type. thanks
I've got an L series front swaybar sitting at my parents' place in Carine. Yours for $10 if you pick it up. Might still have a knackered driveshaft or two lying around as well, but I'll have to confirm that tomorrow.
Dane.
Dane.
put wrx motor and box into brumby. use l series lower arms for added caster and camber. machine arms to use wrx struts and brakes. need drive shafts cause they longer that my ones and shorter than wrx ones.
steptoe i think i can change inners on shafts to ej gearbox, and outers to wrx ones? and the length should be ok for me.
god, if you got the links for sway bar on it i will have it, let me know bout drive shafts. keen to look at rear l series shafts as well, cause may need to widen track on rear of ute
ta.
ta.
sounds cool. Whats the plan for rear hubs how are you going to attach the WRX ones? Are you getting Crossbred hubs?
