lseries bits
wrxer
lseries bits
Post by wrxer » Thu Jul 30, 2009 11:17 pm
am converting my brumby, chasing some bits: front l series driveshafts, stuffed is fine, front sway bar and couple window winders if they fit brumby. can get rid of my/brumby roo bar with brackets alloy tube type. thanks
GOD
Post by GOD » Thu Jul 30, 2009 11:36 pm
I've got an L series front swaybar sitting at my parents' place in Carine. Yours for $10 if you pick it up. Might still have a knackered driveshaft or two lying around as well, but I'll have to confirm that tomorrow.
Dane.
Post by steptoe » Fri Jul 31, 2009 10:06 am
I am curious as to what you are gonna do with L series driveshafts - L series lower control arms ? and L series brakes?
wrxer
Post by wrxer » Fri Jul 31, 2009 9:08 pm
put wrx motor and box into brumby. use l series lower arms for added caster and camber. machine arms to use wrx struts and brakes. need drive shafts cause they longer that my ones and shorter than wrx ones.
steptoe i think i can change inners on shafts to ej gearbox, and outers to wrx ones? and the length should be ok for me.
god, if you got the links for sway bar on it i will have it, let me know bout drive shafts. keen to look at rear l series shafts as well, cause may need to widen track on rear of ute
ta.
Post by AndrewT » Fri Jul 31, 2009 9:42 pm
sounds cool. Whats the plan for rear hubs how are you going to attach the WRX ones? Are you getting Crossbred hubs?
Return to “Western Australia”
