2 different types of whining in MY02 Liberty
taza
Post by taza » Sun May 06, 2012 11:02 pm
El_Freddo wrote:So let me get this right, new reconditioned gearbox with warranty but no LSD, you've got an LSD to fit but have to split the gearbox to fit it?? I'm not sure that this is a wise move if there's an issue with this box under warranty...
It's not the LSD that needs adjusting, it's the diff settings with the preload and backlash that needs to be set correctly.
Oh ok. Nope it won't void the warranty. I actually bought the LSD before I bought the gearbox planing to get bits together to do one later this year. the box just happened to go sooner than I was hoping.
It will get fit sometime but I really don't know when :(
Really? RIPPED!!! I'm using an LSD oil in my gearbox at the moment - it shifts better with this stuff, looks like oil but certainly didn't cost $100 for 5L!!
I did previously have Castrol stuff in and it was sh1t. I then swapped to Penrite LSD (good sh1t anyway) which was ~$55 a bottle (2.5l to a bottle) and this made it shift much better. I didn't put the Red Line Light Weight stuff in as thats around $200 for 5L. I will again be putting the Penrite stuff in this week when the box goes in. Hopefully the box will be here tomorrow otherwise Tuesday :D
d_generate wrote:Tazza if you've got an OBX diff I think it just gets thrown straight in as is.
Really??? I have the LSD sitting in the boot of the car. Currently no plan of when it will be going in... :(
d_generate
Post by d_generate » Mon May 07, 2012 2:01 am
Want me to ask my mate what he'd charge to split the box & put it in for you before you put the new box in or oil in it so there is no cleaning up...He did mine and just put one in my son's RA STI box....That's provided it's an OBX though he can do both.
Venom
Post by Venom » Mon May 07, 2012 6:07 am
At the end of the day to stop that tyre noise will require new tyres. The front to back trick is just a diagnostic test, but it might quiet it down enough to put up with it. Its suprising how loud they can be, i drove a 350z at work that sounded like it had a helicopter under each wheel arch.
zoliberty
Post by zoliberty » Mon May 07, 2012 9:55 am
Venom wrote:At the end of the day to stop that tyre noise will require new tyres. The front to back trick is just a diagnostic test, but it might quiet it down enough to put up with it. Its suprising how loud they can be, i drove a 350z at work that sounded like it had a helicopter under each wheel arch.
Well, I only purchased these tyres in October last year. I haven't rotated them yet. I miss my Yoko's from years back, so quiet, soft compound, it was on a 2wd, so they lasted quite a while.
I went to put in more oil but I can't seem to get a proper reading on the dipstick, I clean the dipstick and re-insert it and the oil seems to cover the stick above the hi notch, the transmission is also cold, so I guess that it's full?!?
taza
Post by taza » Mon May 07, 2012 12:54 pm
d_generate wrote:Want me to ask my mate what he'd charge to split the box & put it in for you before you put the new box in or oil in it so there is no cleaning up...He did mine and just put one in my son's RA STI box....That's provided it's an OBX though he can do both.
Yeah that would be great!
zoliberty
Post by zoliberty » Mon May 07, 2012 5:31 pm
I just spoke to a wrecker, he thinks that the worst case scenario cost wise would be $2200, he cracked it when I mentioned a WRX replacement box saying that it's double the cost and not geared right for N/A Libs. I'm going to drive to some mechanics in the next couple of days.
d_generate
Post by d_generate » Tue May 08, 2012 3:57 pm
It takes very little oil to overfill the box, probably 250mil from just reading to the correct height on the stick, we filled my son's gearbox last night and it was 50mil at a time to get it right.
I'll try to remember to give him a ring tonight Taz
taza
Post by taza » Tue May 08, 2012 9:47 pm
d_generate wrote:It takes very little oil to overfill the box, probably 250mil from just reading to the correct height on the stick, we filled my son's gearbox last night and it was 50mil at a time to get it right.
Got the message, thanks.
Does overfilling the gearbox hurt it? I know you should never over fill an engine with oil..
d_generate
Post by d_generate » Wed May 09, 2012 2:03 am
Might spit your dip stick out?? we put just under 3.5L in it but yours may take a little less with the extra hi/lo gears in it.
Post by steptoe » Wed May 09, 2012 8:51 am
Nulon G70 additive for manual gearboxes only, has some benefts, $25 at many good car parts joints. Some people drive a noise until it gets worse- making it easier to identify, or drive until it lets them down, or trade it in and not even have it test driven by the dealer :) , then the dealers wholesaler gets it, finds noise and reaches for a little G70 :D
There is a few L Series out there I wish someone would fix before they die a noisy death
zoliberty
Post by zoliberty » Wed May 09, 2012 7:08 pm
Well I went to three mechanics today.
Mechanic 1.
I took the car for a drive, he chucked it on the hoist and listened to all four corners and the diffs and transmission with a stethoscope. He said that the front left wheel bearing is slightly noisy and the right is more noisy but the rear diff sounds fine and around the transmission area sounds normal, guy in the car was in the 3rd and 4th gear. I was told that if the bearings are not the issue then I don't have to pay or can reach an agreement for half payment. They also have a courtesy car. Total cost for full rebuild $4000 or can go second hand for a lot less. $350 front wheel bearings. Repair time is around 5 working days.
Mechanic 2.
I took the car for a drive, I also drove in reverse with the car fully locked to turn left, he said that it could be the Viscous Coupler and he said that it could of strained the centre diff. Cost could be from $1500 to $2000, he has to send the box away to reco. I doubt that they have a courtesy car and repair time is around a week. He also said that the wheel bearings IS NOT the issue.
Mechanic 3.
He took the car for a ride, said that it sounds like the rear bearings in the box, luckily that he can partially remove the box but worst case scenario is 3 x $800, so mininum cost would be $800 or up to $2400 but he doubts that it's all three, the rear bearings he can do in a day, he said that it could also be the mains gears one or two and that could take a little longer as this has to be ordered cost $800 and the Viscous Coupler is around $800. He has a courtesy car but he is also the closest. He also said that the wheel bearings IS NOT the issue.
zoliberty
Post by zoliberty » Wed May 16, 2012 8:07 am
Wow, I can't believe I got no reply.
