Engine stalls when clutch pressed in
Post by RSR 555 » Fri Mar 22, 2013 7:01 pm
If you need to use the car everyday, I'd suggest you buy a secondhand (known good one) and fit that, then you can rebuild/rekit your one at your leasure.
Call KPM Industries (aka Guyph) and see if he has one. If not try Gumtree
jims
Post by jims » Fri Mar 22, 2013 8:13 pm
Thanks Paul. I might just book it into the mechanics and get them to look at it and tune it up.
Post by steptoe » Fri Mar 22, 2013 8:33 pm
jims wrote: Sorry guys, i'm thinking out loud more than anything.
Isn't that what a forum is for ??
jims
Post by jims » Fri Mar 22, 2013 8:57 pm
I guess it is :) thanks for your input!
jims
Post by jims » Fri Mar 22, 2013 9:02 pm
Ps I have another dizzie sitting around. Do you think it would it be worth trying swaping it over with the current one?
Post by steptoe » Fri Mar 22, 2013 9:24 pm
compare the pair ? Is the dizzy the same for starters ?
Not idea of swap to fix that idle eh?
jims
Post by jims » Fri Mar 22, 2013 9:39 pm
Sorry, forgot to say it's a dizzy of another L series (same type).
Post by RSR 555 » Sat Mar 23, 2013 3:17 am
Don't think it's a dizzy issue.. more likely a carby issue
Post by steptoe » Sat Mar 23, 2013 6:59 am
might make jim feel better trying it :)
jims
Post by jims » Sat Mar 23, 2013 11:01 am
Hah, okay thanks
tambox
Post by tambox » Sat Mar 23, 2013 11:53 am
It sounds like carb or vac leak.
Are all the hoses in the correct places?
If its in the carb, it seems to be in the idle stage, you can do a "bushies" reverse flush.
Take the air cleaner lid off, have a rag big enough to block the top of the carb. Rev it to about 4000rpm, then cover the top of the carb with rag, at the same time give it full throttle. Leave the rag there until it gets down to about 1500 rpm, remove the rag and control the revs with the throttle. It will self flood/reverse flow the air jets, flushing them out.
So when remove the rag, it will be flooded, if it stops, crank it with full throttle to start.
Do this a couple of times is all thats required.
Carefull, it can backfire whilst doing this if you do not seal the top of the carb properly, so be ready for it, do it properly, no backfire.
Cheap and easy to do.
L serious, still.
Post by Silverbullet » Sat Mar 23, 2013 1:15 pm
I had this on my MY wagon, it was worse in the cold but once it warmed up it nearly always went away. I always thought it was something to do with the pre-heating at the manifold i.e when the engine/water was cold there was no pre-heating of the fuel vapor going on, maybe causing the issue.
*Edit* just read above, vacuum leak also a possibility
jims
Post by jims » Sat Mar 23, 2013 1:38 pm
Thanks guys,
I had some success this morning. First I got a can of carby cleaner and sprayed it all around the vac hoses like Steptoe suggests in another thread. No rise in idle, no apparent vac leak.
So next I got the carb cleaner and gave the inside of the carb a good blast. Focused mostly on the idle jet. Then, with the key in the accessories position, I disconnected/connected the wiring harness to the carby and made sure the idle solenoid valve opened and closed (you can hear it click). Did this a few times to make sure it was free. Then I removed the Pcv valve, cleaned it out, and replaced.
Started her up and she is idling happily at around 800-900rpms. There is none of the surging or spluttering that I was having yesterday. Took it for a test drive and the revs held when coming to a stop and putting the clutch in.
Hopefully something of the above sorted it. I will keep driving it for the new few days and see if it stays happy. Will let you know.
James
jims
Post by jims » Sat Mar 23, 2013 7:24 pm
The plot thickens...
After twenty mins of driving, I slow down in neutral and it conks out and won't hold an idle. It went from idling perfecting to spluttering and stalling again.
jims
Post by jims » Sat Mar 23, 2013 7:57 pm
acutally, come to think of it, it has done this a few times. Idled perfectly in the driveway but as soon as it heats up (driven for 20mins or so) the idle starts stuffing around. Could a temp sensor have something to do with this? I have spare parts to test with.
jims
Post by jims » Sun Mar 24, 2013 10:55 am
Running fine again this morning. Definitely only seems to be only a problem once it has warmed up...
tambox
Post by tambox » Sun Mar 24, 2013 11:37 am
Inlet manifold to head bolts loose or gaskets leaking?
Common vac leak point or coolant into the inlet ports as the engine warms up and the cooling system pressure come up.
L serious, still.
Post by RSR 555 » Sun Mar 24, 2013 12:13 pm
Sounds like your carby is getting enough full to idle but not enough to run the engine at higher RPM. I would check/replace your fuel filter and check the output pressure on your fuel pump.
And on the water temp side, how's the radiator level been?
jims
Post by jims » Sun Mar 24, 2013 2:33 pm
I replaced fuel filter about 4 months ago. The engine does rev and run at higher rpms fine though. Only when it drops down to idle when warm does it start to splutter.
It is running quite cool at the moment. Ranges from 1/8th of 1/4 on the coolant temp display.
How would I check the output pressure of fuel pump?
Post by RSR 555 » Sun Mar 24, 2013 4:10 pm
jims wrote:I replaced fuel filter about 4 months ago. The engine does rev and run at higher rpms fine though. Only when it drops down to idle when warm does it start to splutter.
To me, it still all sounds like a carby issue.
Sorry I meant what is the coolant level like in the radiator after a the run?
To check the fuel pressure, you'll need a pressure gauge...
http://www.ebay.com.au/itm/Car-Carburet ... 5aeee601b7
