newb question Vacuum gauge installation...
M3TA4
Post by M3TA4 » Sun Dec 27, 2009 10:57 pm
I'm installing a vacuum gauge to the car...
and been testing some hoses to where the best vacuum comes out, But none of them seem to be doing the right thing..
When starting the vehicle most of them are not even moving the needle.
and the ones that are it move upwards when hitting the gas pedal.
I must being doing something wrong.. If any1 has a vacuum gauge installed on a 1985 l series(EA81) and could share a photo of where they have the vacuum hose attached would be more then greatful.
[SIGPIC]http://www.ausubaru.com/forum/image.php ... 1261390505[/SIGPIC]
Yes, It's stock factory. But after new years. I'm going to be installing....
body-lift kit, Bull-bar, Spotties, UHF radio, roof racks and 14inch rims....
Maybe even a snorkel, cannon and rear disc brakes....
Post by Gannon » Sun Dec 27, 2009 11:06 pm
There is a vac line that goes up to a white canister behind the drivers side strut tower. Get a T and join into the line between the engine and this little white canister
M3TA4
Post by M3TA4 » Mon Dec 28, 2009 12:00 am
are you talking about this one?
Post by Gannon » Mon Dec 28, 2009 7:32 am
Bingo!
There will be a line that runs from the intake manifold, to this canister (i believe there is already a T there that goes to the 'idle up solenoid' for the Air Con)
Put a T next to it and run your gauge from that
M3TA4
Post by M3TA4 » Mon Dec 28, 2009 8:41 am
Thank you suparoo
it totally worked. and now its running. ill send pix of the install gauge a bit later. Its just a lil dodgey as i put it on the steering colum. Ill be moving it to the pillar once i get a pillar pod set-up.
M3TA4
Post by M3TA4 » Mon Dec 28, 2009 9:22 am
here is the dodgey home made coak pod i made :P
subarooster
Post by subarooster » Mon Dec 28, 2009 10:04 am
Not badd, i did the same to my carbie'd L but when i did it a while back i think mine was more along the lines of "Make your N/a car look like its running boost." haha Ohh well it still looked alright and came in handy wen i got the weber.
End Hijackk. :S
01' Liberty B4.
Post by steptoe » Mon Dec 28, 2009 12:05 pm
85 L Series EA81 ? I hope it was really an EA82 in your L Series
M3TA4
Post by M3TA4 » Mon Dec 28, 2009 7:23 pm
yeah its mainly for them hills and petrol use. cant wait for the oil temp and pressure gauges and the tri pod pillar.
