L Series Overheating? Help!
Newsoob
Post by Newsoob » Tue Jan 01, 2008 1:17 pm
G'day, Does anyone have an idea as to why my 1990 L series is overheating. It overheats/boils in approx. 10 kms. There does not appear to be a leak from a hose or the radiator but the gauge goes up quickly and you can hear a loud "hissing" noise slowly building up? Many thanks Newsoob.
Matatak
Post by Matatak » Tue Jan 01, 2008 1:40 pm
mmmm headgaskets?
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Cam
Post by Cam » Tue Jan 01, 2008 1:41 pm
take the thermostat out and see if it still overheats. The ones i've had around that age seem to block up and stop opening.
Hissing noise might also be low coolant level.
Just hope its not a blown head gasket
stephendean
Post by stephendean » Tue Jan 01, 2008 2:16 pm
It could be that the Radiator needs a good clean. I had a similar problem but after a good clean all is good now.
Post by Alex » Tue Jan 01, 2008 2:53 pm
SEARCH! its your friend, this has come up sooo many times before
Post by AndrewT » Tue Jan 01, 2008 3:14 pm
- check the fans are working
- bleed the cooling system, see if you have a big air bubble somewhere
- flush the cooling system, see if it's clogged up with brown stuff
- if it's clogged then get the radiator "rodded" (they take the end tanks off and shove a rod down each water gallery to clear out any muck)
- check you have enough coolant, it might be low
- take out thermostat and test it by boiling it in a pot on your stove, see if it opens up. Run the car without a thermostat too to see.
If these aren't it then it might be something more expensive like a failed water pump or a breach of the head gasket(s).
Post by AlpineRaven » Tue Jan 01, 2008 10:42 pm
I'd put money towards on the radiator that is blocked! and replace thermostats.
Newsoob
Overheating...Thanks
Post by Newsoob » Wed Jan 02, 2008 9:43 am
Gday again, Thanks for all the replies. Changed themostat, Flushed radiator. refilled with new coolant then started and ran car. After few mins noticed small coolant leak from 6" long small diameter hose tucked away at base of carby.It appears thats where I was loosing coolant from.Pulled out hose to find 1/2" long split. Repaired and all appears to be OK. Thanks heaps for all help and ideas!!
Post by AndrewT » Wed Jan 02, 2008 10:17 am
Ah yep that little hose is a real bugger, I had that problem on my old wagon and plenty of other people too! Hopefully it's all good now.
