hi everyone
i asked this question on the last forum, before it got destroyed, so i need to ask again
which heads/block combo are doable???
i want to keep running carb gear on a n/a engine
i have a good block and good manifold/carb set up.
will spfi / mpfi / turbo heads work??????
also
i have a good turbo block, but wrecked heads, will modified mpfi heads work???
and finally, how do you tell the differance between std heads and mpfi ones?? something with the ports i presume???
sorry if i have asked some dumb questions, i ust wanna confirm some things.
thanx all
VARIOUS EA82 HEADS TO VARIOUS BLOCKS QUESTION
- Wraith
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
There are only two types of dumb questions:
1) Those posted in the wrong forum
2) The question that goes unasked
Seeing as this is in the right forum I guess its not so dumb now is it!!
More on topic . . . The EFI/Turbo heads have twin inlet ports. The carby heads do not (yes I know there are other differences but
You cannot use a carby EA82 manifold with MPFI heads, yet you can use MPFI heads on any turbo EA82 block, with the associated MPFI manifold of course.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry
- Wraith
ok mudrat, can u use standard carby gear/manifold etc, on an spfi heads and block???????
the reason i ask this, is because i have access to a fully rebuilt spfi ea82, but no manifold/fuel delivery devices.
so, will my carb/manifold bolt onto a spfi block and heads?????
i ask because u made no mention of spfi in your reply.
i hope you can give me a positive answer muddy
thanx
thanx
