Removing Gear box input shaft??
Anyone know how i can remove the input shaft from an L series gear box... I want to use it as a Clutch aligninng tool.
Dave
Dave
MY STI was right... we ended uo just chopping it off... and your right... it works GREAT!!
Dave
Dave
- tim_81coupe
If you're a real Subaru dude you don't need a clutch aligning tool, you just do 'the trick'. I talked about this in another post just recently.
Hint: the starter motor on a Subaru is on the gearbox side, this is not the normal spot for one. It allows access to certain bolts that you wouldn't normally be able to get at, thus the existence of clutch aligning tools.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- Outback bloke
I just hacked the ones I have off the front too. Then I welded a piece of pipe cut from some old handle bars to it about 4 inches long and then slid an old handle bar grip on to it. "Looks like a bought one" and is harder to lose and easier to get out of the spigot/clutch when you got greasy/oily hands.
If you really want to show off get some BMX free style grips. You will look ful-sik then.
Yeah i know the "trick" Tim... i belive i was the one who told you about it. We only decided to make and use a tool cos we had a stuffed gear box sitting there so it seamed like a good idea.
BUt i must admit... if u have an old broken box sitting around its well worth doing.... although the "trick" does get the job done.... having a perfect alighning tool makes the job much faster.
Dave
Dave
