F*#ked steering
- Lapsed
F*#ked steering
My steering has crapped itself! The right hand side bush has been leaking fluid for a while now and it had finally ran out of fluid. What is easier to do replace the whole rack or just the bushes?
cheers chris
cheers chris
- tim_81coupe
If the fluid is leaking there is an addative that is pretty damn good that Super Cheap sell (not super cheap brand) thickens the PS fluid making it less likely to leak. As Tim says... bushes are greased if anything... no fluid... would have to to be the PS fluid leaking and not related to the bush wearing out.
And they are more like ball joints than bushes... maybe im on the wrong track.
Dave
Dave
- tim_81coupe
Any pics of the leaking bushes?
How does the car feel to drive?
Have you noticed a change in your power steering fluid level? As Subarino stated, there is some very good gear on the market to stop these leaks.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry
The leak stuff i thought was a pretty standard thing u would need to add to any rack over 10 years old. You can simply use it as a top up or use it as an entire fluide replacement if the leak is hardcore.
Dave
Dave
