Box jammed in 5th
TW83
Box jammed in 5th
Post by TW83 » Sun Feb 04, 2007 9:45 pm
EJ22 5spd AWD gearbox in an MY Touring wagon. I was sitting in the car shifting through the gears with the clutch in and the engine not running. When I got fifth there was no way it was coming back out. Tried a few things but it is firmly stuck. This was probably the first time it has been put into fifth in this car (not yet driveable). Any deas why its stuck or how to get it out?
ps. had taken box apart to put L series stub axles in to achieve the appropriate number of splines
daza
Post by daza » Sun Feb 04, 2007 10:32 pm
You would have had to mod the linkages to fit it, first check would be for them fouling?
Daza.
:D
Post by AndrewT » Sun Feb 04, 2007 11:21 pm
Yeah definitely check linkages.
Wow thats an interesting approach regarding splines...most people just swap the inner cups to suit whatever gearbox is going in.
TW83
Post by TW83 » Mon Feb 05, 2007 9:04 am
AndrewT wrote:Yeah definitely check linkages.
should of in hindsight
TW83
still stuck
Post by TW83 » Tue Feb 06, 2007 10:58 am
More info - its still jammed in 5th. It has NOT picked up 2 gears as it still moves. The linkages aren't stuck on anything. It feels like the selector mechanism. Any more ideas or do we just have to take it all out again ???
Tks
SuBaRiNo
Post by SuBaRiNo » Tue Feb 06, 2007 5:50 pm
Has it worked at all since u pulled it apart???
Maybe something went wrong when u put it back together.
Dave
Brumby Boy
Post by Brumby Boy » Tue Feb 06, 2007 11:50 pm
SuBaRiNo wrote:Has it worked at all since u pulled it apart???
Dave
Yea did you check you had all the gears and check that the input/out put shafts moved in each gear?
RIP 1992 Brumby
TW83
Post by TW83 » Wed Feb 07, 2007 8:57 am
I am pretty sure we checked all gears and shaft rotation after putting it back together. The only doubt is that without the shifter mounted properly, we may have been getting 3rd instead of 5th.
