ej20g into L series
suba_dooba
Post by suba_dooba » Wed May 30, 2007 3:28 pm
alright yeah. ill check it out. if ej20g is gonna be too much of a hassle im getting an ej22 asap
1991 Subaru L series enduro wagon--3" lift, kings, gabriels front with kybs back (no longer kybs back due to strut plates breaking at wedge), cb, .... Future mods are a pipedream at the moment due to money issues.
I really should start thinking of making a picture for my sig
Ben
Post by Ben » Wed May 30, 2007 8:02 pm
NA motors are easy to do
Needed is a motor and harness $1000
Adaptor Plate $150
Surge Tank $100
Fuel Pump and Filter $200
Modified flywheel $150
Exhaust $200
I can't remember what I paid for each bit individually, but the numbers I have put are approx what would be paid.
The only piece of work that I farmed out when I did my last conversion was the power steering hydraulics and the exhaust. The PS stuff was done by a mobile hydraulics guy who basically worked side by side with me to machine up and solder the parts to do the job. I think I paid about $30 for the hour he was with me.
Buy the wiring harness cd of ebay and cut everything that doesn't go into the ecu out of the harness
Buy a piece of 12 or 16mm aluminium plate and cut the adaptor plate with a jigsaw.
Surge Tank, Fuel Pump and Filter can be purcahsed from ebay.
Modified Flywheel - I did this the bodgy method, ie drilled out the holes to make them big enough to line up on the EJ right. The dollar value I put up is to get it done a little more accurately by a engineering shop on a mill.
Other bits and pieces of wiring, fittings etc would in no way add up to more than $500.
Please watch before posting!
Post by Alex » Wed May 30, 2007 10:10 pm
custom dual core radiator will have to get made up too. 4muff and i payed abit too much at $500, you will also need some decent thermo fan(s).
Post by Subafury » Wed May 30, 2007 10:26 pm
u also forgot heavy duty clutch/ beefed one at about $400 i think?
for you sean i would go for the ej22. ej20g also takes longer and could be more of a hassle like alex said if youre not so mechanically skilled.
Ben
Post by Ben » Wed May 30, 2007 10:56 pm
Standard EA82 clutch sat behind my EJ20 NA motor. I'd rather have a clutch as the weakest link than a gearbox! Not that a 92kw engine is giving that much grief to a L gearbox...
Bigger radiator isn't that much a necessity, not all EJ's have mega radiators, just a decent single core will do the job. I had a pair of super cheap thermos still laying around that I used, thats why I forgot to include...
PeeJay
Post by PeeJay » Thu May 31, 2007 9:49 pm
One point I forgot to mention - Acceleration in Low range from an EJ20 Turbo is a thing to behold!! (Just don't drop the clutch or be harsh with the gear changes)
vidler
Post by vidler » Fri Jun 01, 2007 2:15 pm
90subiewgn wrote:custom dual core radiator will have to get made up too. 4muff and i payed abit too much at $500, you will also need some decent thermo fan(s).
i paid about that when i got mine modded, but i had to fork out the cost of a new radiator first, so all up mine cost me about 850:) but if you can mod the radiator in your car now you'll be looking from 400 to 500
09 Forester XT Touring Wagon
BrennyV
Post by BrennyV » Fri Jun 01, 2007 2:32 pm
i think it was a fair price
Hunter S. Thompson
